"1vyrain" - xx30 ThinkPad Jailbreak - Overclocking, Advanced Menu, ME Disable, Whitelist automated unlock with software!
Re: "1vyrain" - xx30 ThinkPad Jailbreak - Overclocking, Advanced Menu, ME Disable, Whitelist automated unlock with softw
Well I stumbled my way through the process of Ivyprep and 1vyrain and everything seems to be working great. I installed the Intel AC 7260 wifi card and the newest Bluetooth Daughter card. And Bluetooth is definitely better!
Update: This morning I used Lenovo Vantage to update the drivers. And now the Bluetooth is acting choppy again.
Any suggestions how I can get last night's Bluetooth drivers back?
Update: Went into Device Manager and deleted Bluetooth then restarted and scanned for hardware changes and Bluetooth is working perfectly again.
Does 1vyrain remove battery check for original in T430s or still need to do Hamishcoleman Thinkpad-EC hack?
If still need Hamishcoleman Thinkpad-EC hack, can it be done AFTER 1vyrain install? (I already 1vyrain v5)
Thank you.
Thank you.
I'm trying to follow the instructions on the 1vyrain github to have a custom splash screen on my T430. I've spent about 6 hours on this now. I'm reticent to raise an issue on Github because I searched all the issues and online and no-one else seems to have this issue,... so it must be me?
I downgraded to BIOS 2.64 using the original Lenovo tool applying the LOGO1 / LOGO2 files and it works fine. Nice splash screen.
I read back the BIOS that has the custom splash screen.
verbose output
Looks fine? Executing without -VVV produces no errors.
I download the latest 1vyrain repo and run the .sh script, which chops off 4megs of the file, then puts it into the patcher binary.
But it doesn't create a patched.rom file.
The script doesn't do anything special.
sudo flashrom -r TEST.FL1 -p internal --ifd -i bios -VVV Code: Select all
flashrom v1.2 on Linux 6.1.31-2-MANJARO (x86_64)
flashrom is free software, get the source code at https://flashrom.org
flashrom was built with libpci 3.8.0, GCC 12.1.0, little endian
Command line (8 args): flashrom -r TEST.FL1 -p internal --ifd -i bios -VVV
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Initializing internal programmer
/sys/class/mtd/mtd0 does not exist
No coreboot table found.
Using Internal DMI decoder.
page_size=1000
pre-rounding: start=0x00000000000f0000, len=0x10000, end=0x0000000000100000
post-rounding: start=0x00000000000f0000, len=0x10000, end=0x0000000000100000
page_size=1000
pre-rounding: start=0x00000000dae9c000, len=0xa28, end=0x00000000dae9ca28
post-rounding: start=0x00000000dae9c000, len=0x1000, end=0x00000000dae9d000
DMI string chassis-type: "Notebook"
page_size=1000
pre-rounding: start=0x00007fb55065b000, len=0xa28, end=0x00007fb55065ba28
post-rounding: start=0x00007fb55065b000, len=0x1000, end=0x00007fb55065c000
page_size=1000
pre-rounding: start=0x00007fb55065c000, len=0x10000, end=0x00007fb55066c000
post-rounding: start=0x00007fb55065c000, len=0x10000, end=0x00007fb55066c000
Laptop detected via DMI.
DMI string system-manufacturer: "LENOVO"
DMI string system-product-name: "23511F4"
DMI string system-version: "ThinkPad T430"
DMI string baseboard-manufacturer: "LENOVO"
DMI string baseboard-product-name: "23511F4"
DMI string baseboard-version: "Not Defined"
W836xx enter config mode worked or we were already in config mode. W836xx leave config mode had no effect.
Active config mode, unknown reg 0x20 ID: 00.
Found chipset "Intel QM77" with PCI ID 8086:1e55.
Enabling flash write... Root Complex Register Block address = 0xfed1c000
page_size=1000
pre-rounding: start=0x00000000fed1c000, len=0x4000, end=0x00000000fed20000
post-rounding: start=0x00000000fed1c000, len=0x4000, end=0x00000000fed20000
GCS = 0xc21: BIOS Interface Lock-Down: enabled, Boot BIOS Straps: 0x3 (SPI)
Top Swap: not enabled
0x7fffffff/0x7fffffff FWH IDSEL: 0x0
0x7fffffff/0x7fffffff FWH IDSEL: 0xf
0x7fffffff/0x7fffffff FWH IDSEL: 0x4
0x7fffffff/0x7fffffff FWH IDSEL: 0x5
0x7fffffff/0x7fffffff FWH IDSEL: 0x6
0x7fffffff/0x7fffffff FWH IDSEL: 0x7
0x7fffffff/0x7fffffff FWH decode enabled
0x7fffffff/0x7fffffff FWH decode disabled
Maximum FWH chip size: 0x380000 bytes
SPI Read Configuration: prefetching enabled, caching enabled,
BIOS_CNTL = 0x2a: BIOS Lock Enable: enabled, BIOS Write Enable: disabled
Warning: BIOS region SMM protection is enabled!
Warning: Setting Bios Control at 0xdc from 0x2a to 0x09 failed.
New value is 0x2a.
SPIBAR = 0x00007fb550668000 + 0x3800
0x04: 0xe009 (HSFS)
HSFS: FDONE=1, FCERR=0, AEL=0, BERASE=1, SCIP=0, FDOPSS=1, FDV=1, FLOCKDN=1
SPI Configuration is locked down.
Reading OPCODES... done
OP Type Pre-OP
op[0]: 0x05, read w/o addr, none
op[1]: 0x35, read w/o addr, none
op[2]: 0x00, write w/o addr, none
op[3]: 0x03, read w/ addr, none
op[4]: 0x02, write w/ addr, none
op[5]: 0xd8, write w/ addr, none
op[6]: 0x20, write w/ addr, none
op[7]: 0x9f, read w/o addr, none
Pre-OP 0: 0x06, Pre-OP 1: 0x06
0x06: 0x0004 (HSFC)
HSFC: FGO=0, FCYCLE=2, FDBC=0, SME=0
0x08: 0x00af5cc3 (FADDR)
0x50: 0x00000a0b (FRAP)
BMWAG 0x00, BMRAG 0x00, BRWA 0x0a, BRRA 0x0b
0x54: 0x00000000 FREG0: Flash Descriptor region (0x00000000-0x00000fff) is read-only.
0x58: 0x0bff0500 FREG1: BIOS region (0x00500000-0x00bfffff) is read-write.
0x5C: 0x04ff0003 FREG2: Management Engine region (0x00003000-0x004fffff) is locked.
0x60: 0x00020001 FREG3: Gigabit Ethernet region (0x00001000-0x00002fff) is read-write.
0x64: 0x00001fff FREG4: Platform Data region is unused.
Not all flash regions are freely accessible by flashrom. This is most likely
due to an active ME. Please see https://flashrom.org/ME for details.
0x74: 0x00000000 (PR0 is unused)
0x78: 0x8bff0b40 PR1: Warning: 0x00b40000-0x00bfffff is read-only.
0x7C: 0x8b100b10 PR2: Warning: 0x00b10000-0x00b10fff is read-only.
0x80: 0x8ade0ad0 PR3: Warning: 0x00ad0000-0x00adefff is read-only.
0x84: 0x8aaf0800 PR4: Warning: 0x00800000-0x00aaffff is read-only.
At least some flash regions are read protected. You have to use a flash
layout and include only accessible regions. For write operations, you'll
additionally need the --noverify-all switch. See manpage for more details.
0x90: 0xc4 (SSFS)
SSFS: SCIP=0, FDONE=1, FCERR=0, AEL=0
0x91: 0xf94000 (SSFC)
SSFC: SCGO=0, ACS=0, SPOP=0, COP=0, DBC=0, SME=0, SCF=1
0x94: 0x0606 (PREOP)
0x96: 0x3f90 (OPTYPE)
0x98: 0x03003505 (OPMENU)
0x9c: 0x9f20d802 (OPMENU+4)
0xa0: 0x00000000 (BBAR)
0xc4: 0x00802005 (LVSCC)
LVSCC: BES=0x1, WG=1, WSR=0, WEWS=0, EO=0x20, VCL=1
0xc8: 0x00002005 (UVSCC)
UVSCC: BES=0x1, WG=1, WSR=0, WEWS=0, EO=0x20
0xd0: 0x00000000 (FPB)
Reading flash descriptors mapped by the chipset via FDOC/FDOD... done.
=== Content Section ===
FLVALSIG 0x0ff0a55a
FLMAP0 0x03040103
FLMAP1 0x12100206
FLMAP2 0x00210120
--- Details ---
NR (Number of Regions): 4
FRBA (Flash Region Base Address): 0x040
NC (Number of Components): 2
FCBA (Flash Component Base Address): 0x030
ISL (ICH/PCH/SoC Strap Length): 18
FISBA/FPSBA (Flash ICH/PCH/SoC Strap Base Addr): 0x100
NM (Number of Masters): 3
FMBA (Flash Master Base Address): 0x060
MSL/PSL (MCH/PROC Strap Length): 1
FMSBA (Flash MCH/PROC Strap Base Address): 0x200
=== Component Section ===
FLCOMP 0x4990001c
FLILL 0x00000000
--- Details ---
Component 1 density: 8 MB
Component 2 density: 4 MB
Read Clock Frequency: 20 MHz
Read ID and Status Clock Freq.: 33 MHz
Write and Erase Clock Freq.: 33 MHz
Fast Read is supported.
Fast Read Clock Frequency: 50 MHz
Dual Output Fast Read Support: disabled
No forbidden opcodes.
=== Region Section ===
FLREG0 0x00000000
FLREG1 0x0bff0500
FLREG2 0x04ff0003
FLREG3 0x00020001
--- Details ---
Region 0 (Descr. ) 0x00000000 - 0x00000fff
Region 1 (BIOS ) 0x00500000 - 0x00bfffff
Region 2 (ME ) 0x00003000 - 0x004fffff
Region 3 (GbE ) 0x00001000 - 0x00002fff
=== Master Section ===
FLMSTR1 0x0a0b0000
FLMSTR2 0x0c0d0000
FLMSTR3 0x08080118
--- Details ---
Descr. BIOS ME GbE Platf.
BIOS r rw rw
ME r rw rw
GbE rw
Enabling hardware sequencing due to multiple flash chips detected.
OK.
The following protocols are supported: Programmer-specific.
Probing for Programmer Opaque flash chip, 0 kB: Hardware sequencing reports 2 attached
SPI flash chips with a combined density of 12288 kB.
There is only one partition containing the whole address space (0x000000 - 0xbfffff).
There are 3072 erase blocks with 4096 B each.
Found Programmer flash chip "Opaque flash chip" (12288 kB, Programmer-specific) mapped at
physical address 0x0000000000000000.
Found Programmer flash chip "Opaque flash chip" (12288 kB, Programmer-specific).
page_size=1000
pre-rounding: start=0x00000000ff400000, len=0xc00000, end=0x0000000100000000
post-rounding: start=0x00000000ff400000, len=0xc00000, end=0x0000000100000000
programmer_map_flash_region: mapping Opaque flash chip from 0x00000000ff400000 to 0x00007fb54f693000
Reading ich descriptor... Reading 4096 bytes starting at 0x000000.
done.
Assuming chipset '6 series Cougar Point'.
page_size=1000
pre-rounding: start=0x00007fb54f693000, len=0xc00000, end=0x00007fb550293000
post-rounding: start=0x00007fb54f693000, len=0xc00000, end=0x00007fb550293000
programmer_unmap_flash_region: unmapped 0x00007fb54f693000
Looking for region "bios"... found.
Using region: "bios".
page_size=1000
Reading flash... Reading 7340032 bytes starting at 0x500000.
done.
page_size=1000
Restoring MMIO space at 0x7fb55066b8a0
Restoring PCI config space for 00:1f:0 reg 0xdc
./patch.sh
4194304+0 records in
4194304+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 35.4726 s, 118 kB/s
Error
Patched BIOS saved as patched.rom
mv *.FL1 BIOS.FL1
dd if=BIOS.FL1 bs=1 of=BIOS.rom skip=464 count=4194304
printf "32442D09-1D11-4E27-8AAB-90FE6ACB0489 10 O:02A0:778B1D826D24964E8E103467D56AB1BA \nF7731B4C-58A2-4DF4-8980-5645D39ECE58 10 P:44243080fb0175080fbae80f89442430:44243080fb01eb080fbae80f89442430 \nF7731B4C-58A2-4DF4-8980-5645D39ECE58 10 P:30488b4338f6000874080fba6c243014:30488b4338f60008eb080fba6c243014 \n" > patches.txt
if grep -q "GCET\|G7ET" *.FL1; then
printf "79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:41390C240F84:41390C2490E9 \n79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:41390C240F858D:41390C240F8500 \n79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:41394C24047577:41394C24047500 \n79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:413AED0F8497FEFFFF:413AED0F8400000000 " >> patches.txt
else
printf "79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:C8390F0F84:C8390F90E9 \n79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:C8390F7516:C8390F7500 \n79E0EDD7-9D1D-4F41-AE1A-F896169E5216 10 P:C8394F0474:C8394F04EB" >> patches.txt
fi
./patcher ./BIOS.rom ./patches.txt -o ./patched.rom
echo "Patched BIOS saved as patched.rom"
you still need the EC hack.
I'd do the EC hack first.
I'd actually not recommend doing 1vyrain since the 802.11n cards work just fine and 1vyrain has a bad habit of wiping out SLIC tables.
sent from my iPhone
T440P; help me with removing whitelist & unlocking advanced menu
by LUC1FER » Sun Mar 15, 2026 11:27 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 1252 Views
Mon Mar 16, 2026 1:14 am
Sierra MC7710 on xx30
by Garlic Bread » Thu Apr 09, 2026 5:52 am » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 222 Views
Last post by Garlic Bread
Can Lenovo Lock/Unlock LTE IMEI on ThinkPad X1 Yoga Gen 6
by ThinkpadX1Dallas » Wed Feb 04, 2026 12:31 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 2 Replies
- 3634 Views
Last post by ThinkpadX1Dallas
Thu Feb 05, 2026 9:12 am
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 10914 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
Users browsing this forum: No registered users and 110 guests
