The official 600 Upgrade and general information Topic
everchanging02
Re: The official 600 Upgrade and general information Topic
Thank you all for the help with the drivers!
Unfortunately, it looks like I'm going to have to dissect the 600 this weekend to determine why the HDD and CD-ROM are not getting any power. If I manage to get it up and running, I'll definitely let you all know how the drivers worked out!
Novice collector (retro-gaming / past workplace nostalgia)
Working: 365xd (x2), A30p, R51 (charges, does not run on battery), R51 (15"), R61i
T4X0: 0, 1, 2 (i7), 2 (i5), 3 (x2)
T4X0s: 1, 2, 3, 5
Repair: 600 (no drive power), T30 (Crit Batt error), R51e (unresponsive at boot)
T4X0s: 1, 2, 3, 5
andromeda92
how to clean the coating of an IBM thinkpad 600, because it is sticky, which product to use.
Thanks in advance.
Thanks in advance.
Thinkpad T42
Thinkpad 600 2645-45U
Thinkpad 390X 2626HNG
Dell inspiron 8200
Toshiba satellite 4000CDS
Dell inspiron 8200
andromeda92
I used isopropanol and it works fine.
Thinkpad T42
Dell inspiron 8200
Dell inspiron 8200
Hello!
I've been meaning to throw a comment in here for a while but had some account issues which Bill had fixed for me. Thanks Bill!
I have a 600x which I want to try to boot off a compact flash card rather than an IDE drive. The card and adapter I have works, as I can install windows on it and boot from it in another (not thinkpad) device, however in the 600x, the card isn't detected in bios as anything at all.
I have a thinkpad R51 which does detect the cf card as an ide drive (but I think it has died because I can't get it to post anymore, and didn't get as far as to image the cf card with my OS..), so I'm positive that the card/adapter is not the issue.
Has anyone had success with getting a 600x to detect a compact flash card in the IDE slot? I've search the thread and hadn't found anything. Though a thread where the device supports booting from the PCMCIA port, but I do not have a CF-PCMCIA adapter to try this out.. Just a CF-IDE 2.5 adapter.
hopgarden53
Hei!
I have not done it in the 600X, yet ... but in an X40 twelve years ago. Pictures:
https://1drv.ms/f/s!ArS1tuLhKalPh7sMUOy ... g?e=zzKSmi
Thinkpad bioses can be tricky when booting - a HD drive or CF card are "not detected". If I remember right, this was my method in this X40 case:
- Cloned the working (and booting) HD to a CF card with a CF to IDE adapter and a proper IDE cable (44-pin, master/slave identification). Used disk cloning software (see the pictures). In this case I used a different adapter as the final "disk" (mastr/slave possibility).
In the 600X I don't know if it is possible to make same kind of cloning - can the IDE slot "see" both master and slave disks (cards)? Or is the ultraslim bay only seen as slave device? Then there is the "normal" method in case of 600X: insert CF card in the disk bay, boot & install with floppies ... which I have not tried for a long time.
T61p (2), X61s, X60, X60 Tablet,T43, R51 1829-R6G, R50p, X40, X32, A31p, A31 2652-MYG, T30 2366-QG7, T23 2647-NG6, 600X (3), 600, 570E
ThinkStation D20, ThinkStation D10
PS2 Note N33x Type 8533
Just recovered my old Thinkpad 600E. Added a new cmos battery, replaced HDD with 8gb ssd PATA drive and installed Windows 98 from recovery cd. Only battery is completely dead. Not taking charge. Any recommendations on how to get fresh battery?
ZBLongladder
Did you ever find a source for a new battery? There's one refreshed on eBay, but they're charging ridiculous prices for them.
SomeDude345
Almost being 27 years old, your best bet will probably be trying to replace the battery cells in your old battery.
As an alternative to replacing cells you could just buy some cheap UltraSlim Bay Battery Packs on Ebay.
https://www.ebay.com/itm/274088270338
Does anyone have a replacement ThinkPad 600 audio/mic cable!
by EpicOtterLover » Sat Jan 24, 2026 4:31 pm » in ThinkPad Legacy Hardware - 0 Replies
- 4671 Views
Last post by EpicOtterLover
- 5 Replies
- 11831 Views
Last post by Python.p
Mon Oct 27, 2025 3:57 am
T440p CPU upgrade + dGPU question
by brendenbogi » Thu Nov 06, 2025 11:19 am » in ThinkPad T430-T495 / T530-T590 Series - 7 Replies
- 14368 Views
Sun Nov 09, 2025 12:07 am
Upgrade SSD & RAM on New ThinkPad While Keeping Warranty – Who Tried It?
by marcusfrank » Wed Nov 26, 2025 8:24 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 13665 Views
Fri Nov 28, 2025 4:18 am
Users browsing this forum: No registered users and 48 guests
