Completely stuck with 2503 Advanced dock and Nvidia 1030
farfignoogin
Re: Completely stuck with 2503 Advanced dock and Nvidia 1030
Hey was looking at Goodwill site today. There is a 2503 advanced dock up for auction…starting at $4.99 plus shipping. I got mine already so just spreading the word!
TRANTOR1972
I played around with this docking station for a while. It is quite difficult to disassemble and assemble!
You can see here what's inside from the photos and the bad video I made!
https://youtu.be/dcZemkl_aAo
https://youtu.be/vsnAWgjL-08
W500tragic
Hi Trantor1972 (hey is that a Asimov "Foundation" series referenceTRANTOR1972 wrote: ↑Mon Feb 21, 2022 10:54 amI played around with this docking station for a while. It is quite difficult to disassemble and assemble!
thanks for the video and the TL:DR highlight version. I appreciate the video as to my knowledge there are no Technical manuals available for the 2503 Advanced Dock - these resources of yours might help to inspire other users to dig into their units for servicing and upgrade, and even for modding purposes.
*Perhaps* you could annotate the video with a brief description of each of the key components you handle? Examples might include the multi-card reader, the video card insertion around 42:00 etc - incidentally, this was the most difficult issue that I found when I stripped back and reassembled my unit - just couldn't seem to get my card (NVIDIA GeForce GT 710) playing nice with the metal shroud intruding into the "back" of the card bay, to enable adequate closure of the plastic bay cover. Had all sorts of short-circuit type issues I think, until I shaved back that shroud a little to give the card more room to fit nicely, and I hadn't any problems after that. Another tricky area was ensuring that the dock engaging mechanism (?) was in correct alignment when closing up - otherwise you couldn't use the dock properly afterwards as the laptop would not be able to clip into place correctly.
Others have mentioned fan unit removal and replacement to deal with unacceptable operational noises - I *was* on that path to have my unit running as close to silent as possible but as I note earlier in this thread a decent video card seems to suppress the effort the card has to make. Nice to see that you have the exhaust fan area well exposed in your video, should others see the need to replace the stock fan with a Pabst fan replacement etc as discussed elsewhere in the forum.
Another suggested annotation regards the replacement DVD dummy unit. In my setup I used the dvd multi-bay drive caddies for swapping additional SSDs' and HDD's for system backups etc for my W500 laptop. Bays not entirely hot-swappable between the 2503 and W500 of course, due to the latter's SATA interface and 9.5mm height requirements - but manageble with the earlier T60 and T61's that I have.
[Off-topic: Unfortunately, my 2503 currently in storage. I had been running Windows 10pro happily on the W500 with SSD, but in two automatic/enforced updates to around v. 20H1 several months ago I recall, I had drastic overheating problems and the poor old 2CoreDuo in the W500 refused to boot up into operation (maybe also the ext3 Linux partitions and dual-booting weren't "playing nice" with the Windows updates). Re-application of heatsink thermals and removal of Win10 from all my 2CoreDuo-vintage machines in favour of 64-bit Puppy Linux versions has proved the ideal solution. Long May the 2503 Serve
T60 (2006; T7200 2.0GHz, 4GB DDR2)
T61 (2007; T9500 2.6GHz, 6GB DDR2)
W500 (2008; T9600 2.8GHz, 6GB DDR3)
X130e (2012; Celeron 857 1.2GHz, 12GB DDR3)
X131e (2013; Celeron 1007U 1.5GHz, 16 GB DDR3)
T440p (2016; i7-4600 2.9GHz, 16GB DDR3)
FS: NOS Frankenpad T61p motherboard 44c3926 NEW 2011 date NVIDIA fx570m fits 14.1 and 15 4:3 t60, t61
by andre#4 » Fri Feb 06, 2026 1:58 pm » in Marketplace - Forum Members only - 1 Replies
- 3514 Views
Last post by andre#4
Mon Feb 09, 2026 9:34 pm
FS: 4:3 T61 motherboard with "fixed" Nvidia Chip
by HiFiGuy » Fri Mar 06, 2026 4:19 pm » in Marketplace - Forum Members only - 0 Replies
- 1599 Views
Last post by HiFiGuy
FS: IBM ThinkPad T61 T61p 15.4" Nvidia 256MB Motherboard
by PiZzA EnGiNeEr » Tue Mar 31, 2026 4:33 pm » in Marketplace - Forum Members only - 1 Replies
- 636 Views
Last post by SKA
Thu Apr 16, 2026 10:51 pm
T440P; help me with removing whitelist & unlocking advanced menu
by LUC1FER » Sun Mar 15, 2026 11:27 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 1187 Views
Mon Mar 16, 2026 1:14 am
Users browsing this forum: No registered users and 128 guests
