T43 Pink tint LCD
T43 Pink tint LCD
I have T43 (2668) and usually I close the LCD lid and put it in sleep mode after daily usage.
I notice there is a pinkish tint around the LCD (especially around the outer edge) in the last couple days when I open the lid and turn on the computer. And a few secs or so, the pinkish tint completely disappears. Any initial diagnosis would be helpful. Thanks.
Re: T43 Pink tint LCD
this means your LCD is slowly on the way out, it won't die just yet.
My T43 LCD has started this behaviour too but that is after 6 years of solid use.
The above "explanation" is rather imprecise and does also not provide any solution(s)... and there are (several) solutions to the problem you are describing.lead_org wrote:This means your LCD is slowly on the way out, it won't die just yet.
First, the symptom you are describing is commonly experienced when the CCFL in a LCD is becoming old; the first moments or minutes after startup (from cold) the LCD may have a reddish or pink color, and then gradually after the LCD has been on for a while, the reddish/pink tint will disappear. While the CCFL can be exchanged (and while a replacement CCFL itself is quite cheap), and while the LCD with a new CCFL will look just as bright and clear as new-born ThinkPad (except, of course, if you have scratches etc on your LCD), the CCFL-replacement operation is considered to be very delicate and is not recommended unless you are technically very experienced - and fearless!
Before making your decision, I suggest you review e.g. the following threads - all found when Googling after e.g. "CCFL replacement site:forum.thinkpads.com" T43 backlit/inverter/? problem and WAAAH! My T41p starts up salmon pink! and Replacement for T42 SXGA+ LCD panel and Guide: How to Replace the backlight in a T4x LCD (soon) and LCD CCFL Backlight Repair/GPU Rework - I'll fix it for you! and How to change CCFL in an LCD? and many more...
Good luck with breathing new life into your trusty old T43!
Johan
Thank you both. It's time to open the laptop for some "surgery"....will be an interesting project.
The same has started happening to my T42p maybe the last week or so... Once this starts happening, how long before the backlight is likely to go completely? I use the laptop for a minimum of 12-14hrs everyday for work so if it suddenly goes completely I'll be up a creek
Also if it does go, would I be able to swap the HDD and RAM into my T42 with little fuss software/driver/BIOS wise?
Many thanks,
Dan
Many thanks,
Dan
T42-2373-M3G: 1.8Ghz 2Gb 160Gb 14" SXGA+ - XP Pro
T42p-2373-HTG: 1.8Ghz 2Gb 120Gb 15" UXGA - XP Pro
Compaq n600c: 1.13 PIII 512Mb 30Gb 14" SXGA+ - Win2k
X31-2672-CBG: 1.4Ghz 1Gb 40Gb 12" XGA - XP Pro (partners)
The pink hue can last for days, weeks, months or in extreme cases, even years.
OTOH, you should be prepared for the CCFL playing 'sudden death' on you.
Either replace the CCFL, the LCD or the whole lid.
You can swap parts between your T42p and T42 no problem.
If the T42 has Intel graphics, all you need to do is install Intel drivers, if ATI you're grand.
One small snag could be a different wifi card, but using the T42 original wifi card you would be fine.
Hi, thanks for the reply
They are different chassis... the T42p being a 15" and the T42 being 14.1" screen... UXGA and SXGA+ respectively. Both are ATI, the T42p being Fire GL2 128Mb and the T42 being the 9600 64Mb, same engine just different amount of memory. The difference is in the WiFi, I think the T42p is slightly older and has an older a/b spec card where as the T42 has a a/b/g spec card, but that is a minor thing for me as i usually use wired in any case
I think I am going to grab a new HDD, use Acronis to clone the T42p main partition and then pop it into the T42 and see what happens, as you say there isn't much difference so I'm pretty confident it should work. When i first got the T42p a couple of years ago it ran like a dog despite having better graphics and double the ram of the T42 so I used a recovery DVD from the T42, and it ran much better
Even if things don't go smoothly I should still be able to use an external screen though so all won't be lost, will just miss all my lovely pixels
BTW I'm in the UK and looking for a replacement CCFL looks tricky though I'm fine with electronics and soldering, I'm not entirely sure what I'm looking for... For example, one site I have found that does supple them, but I'm not sure what I am looking for:
http://search.digikey.com/uk/en/cat/opt ... 570?k=CCFL
The size I think from looking around is 2mm x 305mm, but I have no idea about the other stuff... Is there a service handbook or something I can look for that might help?
Many thanks again,
Dan
Many thanks again,
Dan
This is a thread HOW TO replace a CCFL/Backlight in your LCD I wrote specifically for a 15" UXGA.
Last edited by RealBlackStuff on Wed Dec 07, 2011 11:10 pm, edited 1 time in total.
hi,
I already looked at your instructions earlier when I first picked up the thread, with patience and your steps I think I'll be able to do the replacement but really not sure on the tube spec. Looking on Ebay, I can't find any resellers from UK, all seem to be US, China, Hong Kong and given the delicate nature of the tube I wasn't sure how well they would travel, and of course could take a couple of weeks to arrive so was looking to source one from the UK, that said though you know your stuff, so you know the tube I would need and maybe the kit which I see on your site and can ship it in my direction, that would give me peace of mind too
Many thanks,
Dan
Many thanks,
Dan
Two or three years ago, i bought a replacement tube for my T23 screen from british seller myworld.ebay.co.uk/micro-lite who provided excellent service and communication. Unfortunately, looking at his eBay pages, he seems to have ceased all activity since last April. His contact details (mail and phone) are listed at members.ebay.co.uk/ws/eBayISAPI.dll?ViewUserPage&userid=micro-lite. Maybe you could directly get in touch with him?DannyE wrote:Looking on Ebay, I can't find any resellers from UK, ...
15" 4:3 Standard LCDs as in T42/T42p are 2mm dia. and 305mm length.
http://www.ccflwarehouse.com/20x305mmccfl.html
http://www.lcdparts.net/ccflDetail.aspx?ProductID=1699
Many thanks for the info again RBS and rumbero, all very much appreciated
Sorry for the delay in replying, I've just been weighing up options as I can't realy afford downtime at the moment due to being ridiculously busy with work, so was considering the option of cloning/imaging a drive to put in the T42, for now and then looking at replacing the tube when i get the opportunity.
Something else I looked at was simply plugging in an external monitor, but for some reason if I do that, the laptop just freezes on the IBM start-up screen and never progresses to booting Windows. I'm plugging in via an IBM port replicator II (I think, only has 1 USB port and not 4 on the later version and uses the same power adapter as the laptop, not the 4 pin one), not the full blown docking station. For the monitor to work I have to undock while its booting and then re-dock but because I'm using ps/2 keyboard and mouse/trackball, more often than not the trackball never gets recognised. I am using a Belkin 2-port KVM, could that be the issue perhaps, or has anyone else had any issues with freezing with an external monitor through the port replicator?
Many thanks again,
Dan
Many thanks again,
Dan
At bootup press F1 to go into BIOS, select Config/Display
Change the LCD settings to display 'VGA+LCD' or 'Both' or something like that (don't know what exact wording your BIOS uses).
Perfect, found the options and for the moment have set the screen up as extended desktop, but if all goes wrong I can make it primary I believe until I get time to replace the tube
Many thanks again!
Dan
Many thanks again!
Dan
LCD IAXG01M works in x22, with caveats
by blegas78 » Sun Nov 02, 2025 7:28 pm » in ThinkPad X20/X30/X40 Series incl. Tablets - 3 Replies
- 7534 Views
Last post by Plunkyy
Wed Dec 03, 2025 8:31 pm
Trying to find 14" LCD cable for T60
by Glaurung-quena » Sun Dec 07, 2025 8:32 am » in ThinkPad T60/T61 Series - 2 Replies
- 5512 Views
Last post by Glaurung-quena
Tue Dec 09, 2025 7:38 am
WTB: 600E Replacement LCD panel & ribbon (UK)
by MDBenson » Wed Mar 04, 2026 6:14 am » in Marketplace - Forum Members only - 0 Replies
- 1795 Views
Last post by MDBenson
Users browsing this forum: Bing [Bot] and 94 guests
