SL500, LED backlight -> CCFL backlight ?
SL300/SL400/SL500, L400-L420 and L500-L520 Series
eee3
#1 Post by eee3 » Tue May 08, 2012 9:15 am
I want to replace my WXGA (1280x800) Matte LED to WSXGA+ (1680x1050) Matte CCFL.
But my inverter card has jack for ribbon cable (LED) and I need for another inverter card with 2 pin jack (CCFL). Am I right?
Could you tell me FRU of CCFL inverter card for SL500?
UPD. My inverter card 42W7997
loyukfai
Re: SL500, LED backlight -> CCFL backlight ?
#2 Post by loyukfai » Tue May 08, 2012 9:37 am
Just curious, what would you like to do so...?
Cheers.
eee3
#3 Post by eee3 » Tue May 08, 2012 10:41 am
loyukfai wrote:Just curious, what would you like to do so...?
Cheers.
Why do I want replace the LCD? WXGA (1280x800) is awful.
So, is it possible?
Maybe I was mistaken in the title of this topic. I don't want to replace the backlight of my LCD. I want to use another LCD (1680x1050, CCFL). But there is a problem - different inverter card.
thorcik
Odp: SL500, LED backlight -> CCFL backlight ?
#4 Post by thorcik » Tue May 08, 2012 1:52 pm
You will definitely need to replace at least your inverter card in this case, consult the hardware maintenance manual for exact part nmber.
T60/T61 2637-AB6/8895-W4M, UXGA, T9300, 8GB RAM, Vertex3, Intel WiFi Link 5100
R61 7649-W1Z, T7250, Intel 4965
eee3
Re: Odp: SL500, LED backlight -> CCFL backlight ?
#5 Post by eee3 » Tue May 08, 2012 2:05 pm
thorcik wrote:You will definitely need to replace at least your inverter card in this case, consult the hardware maintenance manual for exact part nmber.
You're right. I cann't find the part number of this card in manual.
LED 1280x800 http://support.lenovo.com/en_US/product ... D=PD002490 , Inverter card 42W7997
CCFL 1680x1050 http://support.lenovo.com/en_US/product ... D=PD002650 , Inverter card 42W7997
I don't understand.
loyukfai
#6 Post by loyukfai » Wed May 09, 2012 1:56 am
My bad, late at night... : )
There's a "LED control card" listed as 42W8219. Perhaps that's the "inverter card" for the LED-backlight screens.
The one you shown in the OP looks like 42W8219. 42W7997 looks differently if I'm not mistaken.
Cheers.
thorcik
#7 Post by thorcik » Wed May 09, 2012 2:49 am
Check also the LCD cable - part numbers for CCFL are different - 44c5375 and 44c9957.
eee3
#8 Post by eee3 » Wed May 09, 2012 2:57 am
loyukfai wrote:My bad, late at night... : )
Cheers.
So, I have 42W8219 and I need this 42W7997 ?
Image is not very clean. Does it have slot for 2 pin jack?
My LCD cable 44c5375 (30 pin).
loyukfai
#9 Post by loyukfai » Wed May 09, 2012 4:16 am
Seems that the cable from the inverter/control board to the screen is different...
Not sure about the cable from mainboard to the screen.
Cheers.
Edit: Anything informative in the HMM (http://download.lenovo.com/ibmdl/pub/pc ... 762_03.pdf)...? Probably start from p.203...
emeraldgirl08
#10 Post by emeraldgirl08 » Fri May 25, 2012 8:14 am
ElvisUnknow wrote:My T400 XWGA LED screen (LP141WX5-T​LP2, 1280x800) needs to be fixed.
But can I replace it by XWGA+ LED (1440x900)? I mean, is it also compatible and replaceable with my machine, though it is different in pixels?
I do not see why not. If your T400 already has an LED screen in it the swap with the WXGA+ LED screen should be painless and fairly easy.
Thinkpad T470 | iPhone XR | mATX Comet Lake Desktop | Hackintosh Monterey | Lenovo L24q-30 Monitor
sampath bandara
#11 Post by sampath bandara » Fri Oct 12, 2012 8:05 pm
hello frends...
I have a sl500 and its backlight was not working now...
I have check and i found that power inverter is not suppling anything to the ccfl pin... In there i have check with a volte meter and i have found one pin have something, but other pin is not responded. I have power in pin from the main board i have got several reading...
I have check out that the little tranformer on the inverter damaged. I have saw there in the out put coil one wire have comes out and it is attached to the one out put path of the transformer. But the other one havent a wire like that.... Is that normal... Plz help me i have struckd here for 3months
Return to “ThinkPad SL and L Series until L420/L520”
