Running a Samsung SSD with openSuse
portsample
I've been using Samsung solid state drives (SSDs) in (2) of my T61 laptops with no problems. OS is current version of openSuse. Recently I have been having a variety of problems with these units that appear to be related to the SSDs.
Question: In the Middleton BIOS, I have set "SATA Controller Mode Option" to "Compatibility", are other people using this setting? TIA...
T61, 14.1", X9000 2.8ghz, Intel GM965, 8gb RAM, 250gb SSD, 1tb SATA Ubay, openSuse 15.1/Win8
(2) T61, 14.1", T9500 2.6ghz, Intel GM965, 4gb RAM, 250gb SSD, openSuse 15.1/Win8 (spares)
Re: Running a Samsung SSD with openSuse
Set it to AHCI, that's the proper way to go.
portsample
My thoughts as well. But problems appear to increase, (failed boots, increased freeze-ups, etc) when I do this.
Are you running a linux OS? SSD? What types of each? Thanks.
That should not be the case. I would suspect that your issues could be related to the way that the drive has been partitioned. How much of an unallocated space is there in percents?portsample wrote: ↑Sat Sep 02, 2017 12:04 pm
I'll answer for myself since I'm replying to your thread...Are you running a linux OS? SSD? What types of each? Thanks.
CentOS 6.9 (32-bit) on a Micron P300 SLC SSD in a Z61m, no issues.
CentOS 6.5 (32-bit) on an Intel X-25E SLC SSD in a T43pSF, no issues. This particular install has been working for well over 18 months at this point, although that system gets very little use, TBT.
portsample
Tried a variety...from 10-20%.
I tend to leave the unallocated space at the very minimum of 25%, usually way more than that. But that's me.
However, given that you've tried 20% and are still experiencing the same set of issues, it's quite likely that your problem is elsewhere.
My first guess: partitioning.
My second guess: the actual AHCI driver.
Good luck.
Good luck.
Which model and whats your fstab say? error logs in more detail? set trim up correctly?portsample wrote: ↑Sat Sep 02, 2017 10:39 amI've been using Samsung solid state drives (SSDs) in (2) of my T61 laptops with no problems. OS is current version of openSuse. Recently I have been having a variety of problems with these units that appear to be related to the SSDs.
Home - Win 10 MSi GF63 Gaming Laptop /Arch GNOME 3/X230 Tablet /X61 [Korean] - Debian 10/T60p - Ubuntu 20.10 Helix 2
Work - Win10/Thinkpad X1 Tablet Gen 2
portsample
/etc/fstab...
UUID=df2cffd2-6298-45e4-be05-8c0bd759b919 swap swap noatime,defaults 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 / btrfs noatime,defaults 0 0
UUID=0ab88e35-74ee-4368-9c32-be0e23afd982 /home ext4 noatime,acl,user_xattr 1 2
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /boot/grub2/i386-pc btrfs subvol=@/boot/grub2/i386-pc 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /boot/grub2/x86_64-efi btrfs subvol=@/boot/grub2/x86_64-efi 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /opt btrfs subvol=@/opt 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /srv btrfs subvol=@/srv 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /usr/local btrfs subvol=@/usr/local 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/cache btrfs subvol=@/var/cache 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/crash btrfs subvol=@/var/crash 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/libvirt/images btrfs subvol=@/var/lib/libvirt/images 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/machines btrfs subvol=@/var/lib/machines 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/mailman btrfs subvol=@/var/lib/mailman 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/mariadb btrfs subvol=@/var/lib/mariadb 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/mysql btrfs subvol=@/var/lib/mysql 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/named btrfs subvol=@/var/lib/named 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/lib/pgsql btrfs subvol=@/var/lib/pgsql 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /var/opt btrfs subvol=@/var/opt 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/spool tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/tmp tmpfs defaults,noatime,mode=1777 0 0
tmpfs /var/log tmpfs defaults,noatime,mode=0755 0 0
UUID=ac801452-3c6a-458d-8896-5f5bd09777d8 /.snapshots btrfs subvol=@/.snapshots 0 0
UUID=6eafd37c-84a0-4432-95f1-9f79ea8f3b60 /externalSpinningHD ext4 defaults 1 2
Trim runs at every boot. Which model? T61 w/intel GPU, CPU is T9500 with 8gb RAM.
No the samsung SSD
ahh x1 thats a very complex fstab
ahh x 2 btrfs - do you routine filesystem maintenance from the likes of https://github.com/kdave/btrfsmaintenance
EDIT: dont run /var/tmp in RAM its meant for permanent tmp files that are active over boots
EDIT: why are your grub partitions btrfs? ie using a journaled fs?
portsample
I have (3) separate SSDs that I've been using: a Samsung 750, an 850 and an 840. All are 250GB.Dekks wrote: ↑Sat Sep 02, 2017 2:17 pmNo the samsung SSD
Are you aware of the samsung 840 performance problem with its TLC NAND? Why all the subvolumes under var/lib? cant you start with a simplified set up
portsample
This resolved my freezing problem,
edit /etc/default/grub. Change the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash blah-blah"
to
GRUB_CMDLINE_LINUX_DEFAULT="intel_idle.max_cstate=1 quiet splash blah-blah"
then update Grub by running,
grub2-mkconfig -o /boot/grub2/grub.cfg
as SU and reboot.
See https://bugzilla.kernel.org/show_bug.cgi?id=109051 for further information. Thanks.
to
as SU and reboot.
Won't that severely reduce your battery runtime?portsample wrote: ↑Tue Sep 05, 2017 10:25 pmGRUB_CMDLINE_LINUX_DEFAULT="intel_idle.max_cstate=1 quiet splash blah-blah"
portsample
Note: Error message associated w/above problem is,portsample wrote: ↑Tue Sep 05, 2017 10:25 pmThis resolved my freezing problem,
to
as SU and reboot.
"drm/i915: Resetting chip after gpu hang".
TIA.
Wait, GPU hang? Maybe it's the Intel graphics driver. The current Debian release defaults to the generic modesetting driver for any Intel GPU newer than the GMA 900/950, due to bugs in the Intel driver.
portsample
Reverting to the previous kernel driver per section 1.4 of below link
https://doc.opensuse.org/release-notes/ ... Leap/42.3/
resolved the problem.
This is NOT a SSD issue, this is purely a driver problem.
I think it's a combination of the 4.9 kernel and the Intel driver in mesa. In one of my X61's I reverted to the stock kernel after encountering problems with kernel 4.9 and the latest Intel mesa driver from backports.
T580 fan starts running moment its turned on
by rotterdam » Mon Nov 03, 2025 4:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 5 Replies
- 11940 Views
Last post by rotterdam
Sat Nov 08, 2025 2:09 am
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 9340 Views
Sun Nov 02, 2025 2:30 pm
Upgrade SSD & RAM on New ThinkPad While Keeping Warranty – Who Tried It?
by marcusfrank » Wed Nov 26, 2025 8:24 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 13923 Views
Fri Nov 28, 2025 4:18 am
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7796 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
