Before this problem I was stuck in a grub rescue screen after trying to install puppy linux, and to fix it I used a boot rescue disc, but after using the boot rescue disc I restarted my computer and it says no operating system found, then this screen appears https://ibb.co/iAHe86 and I have no idea what to do from here. I thought the boot repair disc erased puppy linux after I installed it, so I put in a lubuntu disc and tried installing that, but while I was trying to install it, it said puppy linux was still on my computer, but I don't know how because its not booting. Does anyone know how I can get puppy linux to boot from here?
I'm using a thinkpad w510 and I don't think anything is wrong with my hardware since I can still boot into another operating system like I did in lubuntu, I just want to boot into puppy linux though. And Does anyone know how much a computer shop will charge to fix a problem like this? I will appreciate any help.
EDIT: /viewtopic.php?t=63779
This guy has the same problem as me, but the responses suggest his hardware is faulty, but since I can still boot other operating systems I don't think my hardware is faulty, I just want to know how to boot puppy linux.
Operating system cannot be found, Cannot boot from any device w510
bit_twiddler
Re: Operating system cannot be found, Cannot boot from any device w510
It could be a lot of things. In particular, it sounds like you have puppy linux installed on a hard drive,
so booting off a dvd or cdrom doesn't indicate that your hard drive is O.K.
One place to start would be to do some form of hard drive diagnostics on your hard drive.
If your drive checks out, I'd try getting a drive caddy, and some extra hard drives, setting the BIOS to boot from the drive bay,
and do your installs from an external USB 2.0 dvd reader. This assures that different operating systems
are not going to clobber each other during an install or update.
Daily Drivers: W520 i7-2760QM | W520 i7-2860QM | T420 FHD IPS i7-2640m | W701
Others: W510 | 701C (on its shrine)
Non-TP: Dell m7510
Non-TP: Dell m7510
jaspen-meyer
That picture is saying, "you don't have grub installed on your hard drive."
Years ago I tried using puppy linux as my daily operating system, which is to say not as just a live CD, and the main file, one big squash file with the entire os and data, got corrupted after an unclean shutdown. Perhaps they've fixed that issue, but it was far too unreliable for me and I've never reconsidered using it as anything more than a rescue disk since.
I'm not sure how to install grub from puppy, in version 3.x and 4.x it had something called 'installed MBR'. On debian, or a derivate, you can install grub to a device with:
grub-install /dev/sdX
update-grub
To recover your system, perhaps you can boot into puppy and ask it to search all media for the squash file.
update-grub
T410 cannot boot when assembled.
by phinktad » Sat Nov 29, 2025 11:50 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 9172 Views
Mon Dec 01, 2025 2:57 am
W510 maximum memory
by tpribors » Tue Feb 24, 2026 12:51 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 2 Replies
- 2605 Views
Last post by tpribors
Tue Feb 24, 2026 1:15 pm
W510 Windows upgrades fail
by tpribors » Sat Feb 28, 2026 9:55 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 6 Replies
- 4850 Views
Thu Mar 05, 2026 12:51 pm
Found Windows 7 En-US recovery media for T440p
by CicadaCool » Sun Nov 16, 2025 10:40 am » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 7248 Views
Mon Nov 17, 2025 1:28 am
Users browsing this forum: No registered users and 122 guests
