Pentium 4-M stuck at 1.2 GHz
Raidriar
#1 Post by Raidriar » Wed Nov 15, 2017 9:35 pm
So I thought I had upgraded my CPU to a 2.5 GHz pentium 4-m, but according to NHC, it’s running at 1.2GHz. I am using the 72W adapter from the T43P, my main battery is totally dead. Any advice?
Thinkpads: 760XD, 600E, T23, T30, T43p, T61p
Alienwares: M17x R1, M17x R2, M18x R1, M18x R2, Alienware 18
Razers: Razer Blade Pro 2017 FHD
Re: Pentium 4-M stuck at 1.2 GHz
#2 Post by rkawakami » Thu Nov 16, 2017 2:14 am
To be clear, what system are we talking about here? T2x cannot implement P4 so I'm assuming that you are doing this on a T30. If so, then it's likely that the missing (dead) battery is preventing the system from running at full speed. Try installing a known good battery and re-measure the system speed.
kfzhu1229
#3 Post by kfzhu1229 » Thu Nov 16, 2017 3:18 pm
Also triple-check the BIOS power settings that everything related with speed are set to maximum performance.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
Thinkpad4by3
#4 Post by Thinkpad4by3 » Thu Nov 16, 2017 3:40 pm
Its likely a Pentium M. Even I confuse them sometimes with P4's sometimes.
It has SpeedStep so try and run a benchmark like AIDA to check it. It likely is just conserving power.
Raidriar
#5 Post by Raidriar » Thu Nov 16, 2017 4:54 pm
Sorry for not specifiying, it is indeed a T30 Pentium 4-M 2.5 GHz. I will have to track down a working battery that won’t cost me what I paid for the computer
BIOS settings are set to max performance plugged in and max battery when on battery
kfzhu1229
#6 Post by kfzhu1229 » Thu Nov 16, 2017 8:22 pm
Also, try the latest BIOS. From what I can see, by the time T30 releases, the 2.5Ghz model of P4-M doesn't exist yet, so the out-of-the-box BIOS may not identify it properly.
I did have this problem with my A30 board and 1.2Ghz PIII-M CPU.
UXGA:
#7 Post by ajkula66 » Thu Nov 16, 2017 9:04 pm
Sooner the better, and remove the dead battery altogether now since running with one for an extended period of time may blow your charging circuit.
