T25 keyboard bezel to make T470 a 7-row?
SwissFrank
I was happy with my T400s and T420s. I was going to buy a T470s, then saw the 25, then saw that the T470p was same price and twice the CPU cores.
So I got 1TB SSD, 7700HQ, and 16GB.
And, sadly, the first non-7-row keyboard I've used since 1998.
Obviously the 25 shares most of its hardware with the T470, which means the 25's keyboard bezel probably fits the T470, which means you could probably 7-row a T470 if you could obtain that part.
But I note the official dimensions of the T470p are 1/10 inch wider and deeper, so I'm guessing the bezel wouldn't interchange on my p.
Can anyone confirm or (better yet) deny this assumption?
Re: T25 keyboard bezel to make T470 a 7-row?
AFAIK, no one has yet verified that a Thinkpad 25 keyboard can really fit T470 and work. I don't even remember if someone verified that the connector is physically the same.
As far as T470 vs T470p, the keyboard FRUs are different, so I'm not sure they are physically interchangeable either.
The FRU of the T25 motherboard is the same as the one of asia's T470 with dGPU. So yes, the keyboard connectors of the T25 and T470 are definitely identical.
This indeed might be a problem. And the touchpad, too, it's smaller on the T25 than on the T470 so probably needs to be fitted into a retro T470p as well.As far as T470 vs T470p, the keyboard FRUs are different, so I'm not sure they are physically interchangeable either.
X62s 3rd batch, X210Ai 1st batch, ex. [s]T61[/s] T70 14" 4:3 1st batch
ibmthink on the Subreddit said that the keyboard is wholly incompatible with T470.
sent from my iPhone
evening_hunger
Said it he has, but it's not like he actually tried.
T14amdR7-4750U/32GB/500gb.ssd/debian_testing (main driver)
X320/i7-2620M/8GB/256gb.ssd/FHD13.3''IPS/debian_testing (ex-main driver)
T30Pentium-M 4 1.8Ghz 512MB RAM - under restoration
X230/i5/8GB/500gb.hdd+256gb.m2ssd/IPS/debian_stable+win7
755CE, 486DX, approx 28MB RAM (Win95 JP)
If the motherboard FRU is the same, then the keyboard should be fully compatible. But that's not what I see from the FRU BOMs:
T470
TP 25
It does not make sense to me for the board FRU to be completely the same, because the T470/TP25 also share the BIOS/EC FW. How will the board "know" if it's running a TP25 or a T470?
T470
TP 25
Dang, shouldn't have trusted the info someone posted here or on reddit.dr_st wrote: ↑Tue Dec 19, 2017 2:14 amIf the motherboard FRU is the same, then the keyboard should be fully compatible. But that's not what I see from the FRU BOMs:
T470
TP 25
This is something I’ve been really interested in. I want a TP25 but not for the price and limited specs to just get the keyboard. I’d be willing to swap palmrest and keyboard like I did on my T430s but that’s about it.
Something tells me it’s a pretty straightforward swap - just no ones torn down both computers to see if they’ll physically fit. If they do the firmware/BIOS obstacle is minor by comparison.
Things might change once anyone gets hold of a [spare] T25 keyboard (not available yet AFAIK).
As far as I have heard from people who tried, Lenovo only sells the ThinkPad 25 keyboard to someone who owns the ThinkPad 25 - and it costs 300 $.
The best choice if someone wants a ThinkPad 25 keyboard seems to be to buy the ThinkPad 25 while its still available.
Is it worth it to go to such lengths just for the quad core CPU on the T470p? cause thats literally the only advantage the T470p has over the TP25. I don't get the incessant need for a quad core cpu on the tp25 its not designed to be a heavy workstation. I think it would be a better idea to get a P series if heavy workloads are needed.
2017 TP25 | 2016 X1 Yoga | 2014 X240 | 2007 X61
zoltan87
Is that 300 $ price only a typing error? It surely can't cost that much.Ibthink wrote: ↑Fri Dec 22, 2017 9:32 amAs far as I have heard from people who tried, Lenovo only sells the ThinkPad 25 keyboard to someone who owns the ThinkPad 25 - and it costs 300 $.
Thinkpad T60, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad T601, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad X32
Thinkpad T22
NEC ProSpeed SX/20
Thinkpad X32
Thinkpad T22
NEC ProSpeed SX/20
agarza
You also don't get the WQHD LCD screen on the T25gofishus wrote: ↑Tue Jan 02, 2018 1:38 pmIs it worth it to go to such lengths just for the quad core CPU on the T470p? cause thats literally the only advantage the T470p has over the TP25. I don't get the incessant need for a quad core cpu on the tp25 its not designed to be a heavy workstation. I think it would be a better idea to get a P series if heavy workloads are needed.
Current
T440p: Core i7-4710MQ|16GB RAM|Intel 200GB SSD| 14.1" AUO IPS FHD|Win 7 Pro|T450 Trackpad|Backlit keyboard|2nd Caddy
T460p: Core i5-6300HQ|16GB RAM|lPNY 256GB SSD| 14.1" Panasonic IPS WQHD|Win 7 Pro
Wouldn’t surprise me if it’s priced at $300 to keep people from buying them. Remember all T25s are sold with a 3 year warranty that I think included accidental damage... so who really would be paying for the part at this point anyway?zoltan87 wrote:Is that 300 $ price only a typing error? It surely can't cost that much.Ibthink wrote: ↑Fri Dec 22, 2017 9:32 amAs far as I have heard from people who tried, Lenovo only sells the ThinkPad 25 keyboard to someone who owns the ThinkPad 25 - and it costs 300 $.
It does not.
You'd need T25 keyboard, bezel/touchpad, and power button as well.
sent from my iPhone
Jake.Werecat
A few years went by, anyone tried this mod maybe? Is it feasible partswise?
T14 1st gen
Several people have put the T25 keyboard in the (better) T480.
See also
T480 Modification with Thinkpad T25 7-Row Keyboard
See also
Jake.Werecat
I know
But I find T470 superior in design to T480 due to docking connector. Also I really don't feel like cutting and trimming anything. I know that for a T470 it's a direct fit with no modifications whatsoever, I was rather wondering is a T25 keyboard, touchpad and palmrest obtainable anywhere and if yes, are the prices reasonable.
T14 1st gen
Jake.Werecat
I kept searching and searching, and found nothing, but some strange layout on eBay. But no qwerty-us for T25 anywhere, not to mention other necessary components.
Nothing on eBbay, nothing on Aliexpress, sold out on Encompass. It's basically unobtainium. And I don't even understand why.
In any case - any hint or suggestions where else could I possibly look for those parts? I know that this swap HAS beeen done by more then a few peoples, including forum and/or subreddit members with both T470 or T480, so there must be a way.
T14 1st gen
Perhaps there simply aren't any left?And I don't even understand why.
Funny, just looked on eBay and I see a T25 palmrest and a T25 backlit keyboard.
Jake.Werecat
I know about it, I even mentioned it in my previous post:RealBlackStuff wrote: ↑Wed May 04, 2022 1:19 amFunny, just looked on eBay and I see a T25 palmrest and a T25 backlit keyboard.
The thing is it's an odd Scandinavian layout. Not very useful.Jake.Werecat wrote: ↑Tue May 03, 2022 6:17 pm(...) nothing, but some strange layout on eBay. But no qwerty-us for T25 anywhere
T14 1st gen
ThinkPad T25 ANSI US Keyboard from Amazon
by vermaden » Sun Nov 09, 2025 6:26 pm » in Thinkpad T25 Anniversary/Retro - 1 Replies
- 8270 Views
Last post by David C
Tue Jan 27, 2026 9:30 pm
- 4 Replies
- 3457 Views
Last post by jruschme
Tue Dec 23, 2025 11:51 am
WTB: T60/T60p 15” palm rest and keyboard bezel
by stanleylieber » Fri Oct 31, 2025 4:32 pm » in Marketplace - Forum Members only - 3 Replies
- 6549 Views
Last post by KAQSP
Thu Nov 20, 2025 6:33 pm
T490, Did I make a good investment in late 2025?
by Twarden » Sat Nov 22, 2025 12:35 pm » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 9948 Views
Last post by Twarden
Sun Nov 23, 2025 12:29 pm
