The true size of 1920x1200
TPFanatic
#1 Post by TPFanatic » Sat Mar 03, 2018 11:19 pm
You never realize what you have until it's gone. As presented with my Z60m that refuses to display 1920x1200 in Windows but works fully in Ubuntu. :??:
1680x1050
https://i.imgur.com/HL3ZwFG.jpg
1600x1200
https://i.imgur.com/KVn7BoF.jpg
1280x800
https://i.imgur.com/YBeLzGA.jpg
1024x768
https://i.imgur.com/V4AU2HD.jpg
So you don't get much more than good old UXGA. 160 more columns on each side is a nice boost, but not critical.
QWERTY Andreas
Re: The true size of 1920x1200
#2 Post by QWERTY Andreas » Sat Mar 10, 2018 7:37 am
Widescreen gives the option to view two full pages, side by side. That is something that shouldn't be underestimated by a lot of you - but is.
Thinkpad Helix 2
Custom build ITX desktop (i5 4590, 8GB RAM, GTX 1050Ti, custom watercooling)
Thinkpad 8, Thinkpad W500, Thinkpad T61F 14" (2.53 GHz QX9300, 6 GB RAM, Quadro FX570m 256 MB), GPD win
FS: T61F
#3 Post by axur-delmeria » Sat Mar 10, 2018 8:29 am
Only at high resolutions (FHD and up) and large display sizes, from what I've experienced.
#4 Post by ajkula66 » Sat Mar 10, 2018 2:41 pm
If you're talking about standard Word format, I get that with 1600x1200, no need for a widescreen.
#5 Post by dr_st » Sat Mar 10, 2018 3:48 pm
Indeed it has been mentioned in the past that two A4 pages side-by-side are closer to 4:3 than to any form of widescreen. It is 1.4, which is about half-way between 4:3 and 3:2.
Whether it's more comfortable to view on a wide-screen or a tall-screen depends largely on the other components on the screen - gap between the pages, vertical toolbars, horizontal toolbars, other windows, etc.
TPFanatic
#6 Post by TPFanatic » Sat Mar 10, 2018 7:01 pm
You really need QXGA, QHD, or WQXGA to put two full size web browsers side by side. WUXGA and FHD can do it but there's an overlap, so scaling comes into play, which works practically enough regardless of resolution (except xga).
Users browsing this forum: No registered users and 39 guests
