Hello lovely people,
(first of all, thank you for even reading this question and thank you a million times for attempting to give an answer. I'm always surprised by how people still care about forums in 2018 when Facebook and other social media seem to have taken over the internet.)
recently I've been experiencing this error (0190: critical low battery error) after I press the power button of my X220. I've been reading through some people's posts about this error and one of the topics concerning it seems to be the battery and the charger. I've tried three options:
- With both battery and charger
- Without battery, with charger
- Without charger, with battery
and the scenario is the same all three situations. Pressing the ThinkVantage button does nothing.
Multiple people discussing this error online have suggested that in this case, the issue is probably the motherboard.
1) If that's the case, what does it mean for my ThinkPad? Sorry I'm a noob - does it mean it's dead, are my data lost or can I just replace it with a new one without either of those things being threatened?
2) If it isn't the case, what are other possible reasons for this error? Should I call an IT service?
Thank you sincerely for caring. All my work is inside this machine and I've developed a strong emotional attachment to it , so any responses will be greatly appreciated!
Have a great day,
Kyófú
'0190: Critical low battery error' - X220
Re: '0190: Critical low battery error' - X220
Your data is safe, as your data is stored in either the hard drive or SSD (if your X220 has one). You can buy a complete X220 and just put in the old hard drive and/or SSD to the "new" X220.
I've encountered a similar error only once, when I used a non-spec charger (19v only instead of 20v) on a Thinkpad X61 without any battery installed.
But since you're experiencing it even with only the battery installed, I see two possibilities.
1. Both the charger and battery are malfunctioning. Borrow another charger, one that's known to be good. Remove the battery, then plug in the charger. Turn on the laptop. If the problem disappears, turn off the laptop and install the battery and wait for an hour. Don't turn on the laptop. If the battery charging light blinks orange even after an hour of charging, then it's probably dead.
2. If the problem persists even with a known good charger, then it's highly likely that the laptop's motherboard is malfunctioning. To be specific, the power circuits in the motherboard. In this case, you can either replace the motherboard, or as mentioned earlier, buy a complete X220 and transfer your hard drive and/or SSD there.
Flickering Screen on Low Battery
by MasterLink » Tue Mar 05, 2024 12:18 am » in ThinkPad W530/W540/W541/W550 Series - 2 Replies
- 518 Views
Last post by MasterLink
Tue Mar 05, 2024 10:43 am
Low(er) TDP CPU on T420
by toguro123 » Sat May 18, 2024 8:12 am » in ThinkPad T430-T490 / T530-T590 Series - 4 Replies
- 196 Views
Sun May 19, 2024 2:03 am
X220 Battery Recelling
by N4b00 » Thu Dec 28, 2023 5:56 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 10 Replies
- 4228 Views
Fri Apr 19, 2024 12:34 am
Farewell to my X220...
by axur-delmeria » Tue Nov 28, 2023 12:15 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 5 Replies
- 21363 Views
Last post by mikemex
Wed Jan 10, 2024 5:32 pm
