My T430 didn't come with a bluetooth card and it would be handy to have. NOS cards are cheap on ebay.
My question is, is the cable for it already in the T430? From pictures it looks like it attaches in the middle of a ribbon cable that might already be in there.
Question about adding bluetooth to T430
Elmer Fishtwanger
Re: Question about adding bluetooth to T430
Yes, probably. I don't know that it holds true for every T430 variation, but when I opened my T430, the bluetooth cable was already there, taped to the lid, and connected to the trackpad. Be aware that the device manager won't recognize the bluetooth card until you install the "Lenovo hotkey features integration" software. The software is necessary to turn on power to the bluetooth card.
Plug the Bluetooth card into it's slot and screw it down. That's it. Once you restart, Windows should install the s/w, if not, it's easy to find from most vendors. I build a lot of Lenovo laptops for resale so I include Lenovo System Update that makes it easy to find system updates including s/w drivers. UPDATE: My answer could have been more detailed. The Bluetooth daughter card location for a T430 is under the palmrest cover. It uses 1 screw and the ribbon cable should already be there.
jelabarre59
I don't recall seeing the cable in my T430, so I'd need to find a part number to search for.Niknok wrote: ↑Mon Jul 09, 2018 6:35 pmYes, probably. I don't know that it holds true for every T430 variation, but when I opened my T430, the bluetooth cable was already there, taped to the lid, and connected to the trackpad. Be aware that the device manager won't recognize the bluetooth card until you install the "Lenovo hotkey features integration" software. The software is necessary to turn on power to the bluetooth card.
And regarding that Lenovo software you mentioned; is that a MSWindows-specific issue, or would that apply to ALL operating systems? I run Linux on mine (why sully a perfectly good ThinkPad with MSWindows?
T430 and bloody bluetooth
by jronald » Sun Dec 14, 2025 12:01 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 3857 Views
Last post by ZaZ
Mon Dec 15, 2025 2:18 am
T430 Cooling system
by ShellieACarlson » Mon Mar 09, 2026 7:34 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 1745 Views
Mon Mar 09, 2026 10:41 pm
TrackPoint and Bluetooth problems on T61
by giovanazzi » Mon Nov 03, 2025 7:43 am » in ThinkPad T60/T61 Series - 2 Replies
- 11802 Views
Last post by giovanazzi
Mon Nov 03, 2025 10:37 am
T440p CPU upgrade + dGPU question
by brendenbogi » Thu Nov 06, 2025 11:19 am » in ThinkPad T430-T495 / T530-T590 Series - 7 Replies
- 14501 Views
Sun Nov 09, 2025 12:07 am
