X200s: Fingerprint scanner under Win7
BigCatAndy
I bought some time ago X200s. I occasionally broke the Fingerprint connector, and replaced it yesterday with a new one. Unfortunatetly, I don't see it in the Device Manager in Win7 (although BIOS shows Fingerprint scanner in "Security" section).
Can anyone give me a hint on it? What can be a reason for the missing FP scanner?
Thanks,
Andrey
Thanks,
Andrey
- in use -
(1) TP R61i Frankepad - 4 GB / C2D T9500 / 180 GB SSD / UXGA display
(2) Lenovo 3000 N200 - 2 GB / C2D T7300 / 160 GB
(3) TP T450s
- in museum -
IBM 600x, IBM TP T43p, Lenovo TP Z61t, Lenovo TP X60 Tablet
(3) TP T450s
- in museum -
Re: X200s: Fingerprint scanner under Win7
Hi
Try setting the BIOS to the default settings to see if it is then picked up, otherwise you may need to reseat the cable for the FP reader
https://www.rectech.co.uk
Specialist in refurbished laptops
BigCatAndy
thanks for the hint. I have 2 news:
- I booted laptop with Linux Mint, and could not see scanner also there (lspci / lsusb)
- I made a photo if the connector on the board with my cell phone, with zoom - it looks like one wire would be slightly deformed. But not sure about, because zoom is not sharp enough.
But again: the FP is visible in BIOS. Does it mean, that the device is physically properly connected?
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
BigCatAndy
today I started laptop with SuSe Linux - also no sign of FP on lsusb output. So, I definitely should check the connector. Obviously seeing FP in BIOS does not mean proper work in OS.
Will do it later, when I have some more time.
Andrey
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
BigCatAndy
I disconnected FP completely from the board - the BIOS entry remained. So, my problem is obviously the damaged board connector. Just wondering, if I can fix it manually, with a lot of pation and my house tools
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
High pitched speaker noise under Windows
by NBG » Mon Apr 13, 2026 9:34 am » in ThinkPad T60/T61 Series - 4 Replies
- 791 Views
Fri Apr 17, 2026 12:14 pm
Users browsing this forum: Bing [Bot] and 29 guests
