ThinkPad T410 + i7 quad = possible?
Admin Notice:
For whatever reason, this post seems to be hacked and/or modified with spamming.
The original post might still be somewhere in our backups, but is irrelevant, as OP never bothered to reply.
So I deleted the hacked text and closed OP's account.
Hope this is all there is!
Re: ThinkPad T410 + i7 quad = possible?
These are the fastest processors for that architecture:
Dual core:
Intel® Core™ i7 processor i7-620M (2.66 GHz) with dual core
Integrated DDR3 memory controller (up to 1066MHz), Intel Turbo Boost, 4MB cache
Quad-Core:
Intel® Core™ i7 processor i7-720QM (1.60 GHz) with quad-core
Integrated DDR3 memory controller (up to 1333MHz), Intel Turbo Boost, 6MB cache
Intel® Core™ i7 processor i7-820QM (1.73 GHz) with quad-core
Integrated DDR3 memory controller (up to 1333MHz), Intel Turbo Boost, 8MB cache
Intel® Core™ i7 processor i7-920XM (2.00 GHz) with quad-core
In addition, you may be able to install a Xeon based processor too, but I'm not certain which.
Dual core:
Quad-Core:
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
The fastest CPU that will work in a T410 is actually i7-640M
https://ark.intel.com/products/49666/In ... e-2_80-GHz
No quad core will work in these systems.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Because we are talking here about the smaller T410, NOT the big T510/W510 that you refer to!
The only ThinkPad from that list that supports a QC CPU is W510. Lenovo's info on the subject is often vague and misleading.MikalE wrote: ↑Tue Sep 18, 2018 1:34 pmWhy not?
https://support.lenovo.com/us/en/solutions/pd003320
First generation i7 dual cores and i7 quad cores are similar by name only. They are actually completely different architectures. The i7 duals are Arrandales and the i7 quads are Clarkfields.
More differences:
i7 dual has the MCH with Intel GMA 5700 "HD Graphics" on a separate die on the same removable CPU chip.
i7 quad has the MCH built into the same chip and no graphics on the CPU. It cannot be run without a separate graphics controller on the motherboard, like Core 2.
Wonder why W510 and W701 quad core models do not have integrated graphics? It physically does not exist! As well you cannot put an i7 quad onto a W510 shipped with an i7 dual core, consider it is just a T510 with Quadro graphics.
T410 is not designed to use the Clarksfields. Normally there is no graphics on the motherboard, but that is not the limiting factor. There are machines with Nvidia NVS 3100m dedicated graphics, but even putting an i7 quad on them does not work. Arrandale and Clarksfield are fundamentally different.
One more thing:
Arrandale Thinkpads like T410, T510, and X201 top at 8GB of RAM. Like the GMA 5700HD, it's possible the MCH on Arrandale is based on the same MCH as the Core 2, and unable to use more than 4GB in a stick.
Clarksfield Thinkpads like W510 and W701 top at 32GB of RAM, an 8GB stick in 4 slots.
Again, fundamentally different.
While 16:10 the LCDs in T410 are not much to write home about and max at the low resolution 1440x900. If want a nice screen and a quad core in a classic Thinkpad the best options are:
- T400 with Core 2 Quad mod
- T500 with Core 2 Quad mod
- W510 with FHD and quad
- T520 with FHD and quad
- T530 with FHD and quad
- T420 with FHD mod and quad
- T430 with FHD mod and quad
More differences:
One more thing:
sent from my iPhone
I completely missed that. Sorry about that Chief.RealBlackStuff wrote: ↑Tue Sep 18, 2018 2:02 pmBecause we are talking here about the smaller T410, NOT the big T510/W510 that you refer to!
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
And thank you for the explanations.TPFanatic wrote: ↑Tue Sep 18, 2018 4:09 pmFirst generation i7 dual cores and i7 quad cores are similar by name only. They are actually completely different architectures. The i7 duals are Arrandales and the i7 quads are Clarkfields.
More differences:
One more thing:
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
With all that being said I would look for a T420 mainly because the Arandale runs hotter. Especially if it is to be used for more than just web browsing etc..
Yes agreed the 16:9 ratio is painful but using an external display can solve this issue to a degree.
Active --- Love the X series
X301 W 7/Mint | X201 540M L Mint | X220 2520 W7/Mint
Nostalgia
X61 T7500 / T41 T42 T43 / A31
Nostalgia
1,400 x 900 vs 1,600 x 900 is a pile of garbage anyway given they all used mediocre screens.
Understandable for the 16:10 preference, but remember that anything that is old, does not necessarily mean it is cheaper. Some of the older laptops are priced stupidly high in my area, for example.
Unfortunately for the T410, as the other posts have mentioned, it is not possible to install a quad Core i7 in the T410. If it was possible in an alternative universe where the T410 could use a quad Core i7, the best would be a Core i7-940XM. A post had also mentioned the possibility of installing a Xeon in the T410, but that is also not possible. There are no such Xeons that were available for the rPGA988A socket, only the LGA1156 and the LGA1366 socket of the same generation had Xeons available.jamecloud wrote: ↑Tue Sep 18, 2018 10:45 am- and I'm curious to know what the best possible CPU I could upgrade to might be. I've spent time doing searches here and at the NBR forums today but I can't find anything absolutely definitive about it. Lots of posts across both forums with mention and talk of CPU upgrades, and in the long run I just figured it would actually be easier to just ask outright if anyone has a specific suggestion.
I noted that some folks with the T420 have done a quad i7 upgrade and had no issues, and I do know the older i7 models did offer a mobile quad version or at least one potential quad i7 CPU, so could anyone offer advice or a suggestion about what the "best" particular i7 quad would be for the T410 if I can manage to find one?
Well, don't forget about the extra option being the 15.4" 16:10 or the 14.1" 16:10 T61.
410 and 420s are very cheap here as shell chassis... ie. complete minus hdd and charger
so you need to buy an ssd, say $50 for a 240gb and say $10 for the hdd cover and caddy and then say $30 for a charger... hopefully it has a battery with some charge, even 2/3rd charge is ok
and then your skills with installing win7 and a slic etc.
they are getting to the point they are e-waste given the 410 isnt supported and 1st gen is getting a bit slow now... i see 4gb Intel gfx 410s, some with 1280 some with 1440 x 900 screens for like under $50 usd which is fine if you can get it going but i feel its not worth it on a 410, a 420 maybe but with the lack of USB3 etc.
eh.. we are now talking about 8yr old laptops?
420 with say the latest bios, 8Gb and a 240gb ssd a middling i5 2520/40m is a fine machine on win7. add a express 34 usb card, you got a machine that struggles to hit 2.5hrs if you have an reasonable battery.
About batteries, good luck finding genunine ones. The copies are largely all garbage. For my use case I use them kind of as DTRs so the very least i'm at a desk with a socket and a mouse so that's not super important to me...
Geartooth
Is it just me, or has OP Changed the Post to be a essay on Hospital Mattresses? That or I'm just going insane from the Chilly 24C Hong Kong weather.
Your local Pony.
My Collection: X60, T60, X61, X200, X200s, X220i, T420, X130e, X330, X240, XPS 9350
Sold:E6320, X1C1
Sold:E6320, X1C1
Thinkpad4by3
Something is going wrong..
It changed today??
It changed today??
Someone hacked his account... or 'hacked' as in he left himself logged in and a spammer took over.
This is so funny, that I think I would not remove this thread for the time being.
Nobody looked at, or posted in, this thread between 09/19/2018 and 10/10/2018.
A modification in ANY post is not noticeable, as this does NOT trigger the "Unread posts" group.
Hence nobody noticed the spamming until now, 10 days later.
RBS wrote:Admin Notice:
For whatever reason, the [original, first] post seems to be hacked and/or modified with spamming.
Hi all,
and I'm truly sorry, stumbling across this thread many years later, reading about mattresses, I cant help laughing
I did back in time also investigate the quad-options but i realized (much like stated earlier here) that it was moot. I eventually went for the 640m which i still run with the 1600x900 display and the CPU has actually worked rather nicely ever since (i repasted it early on with Kryonaut). it runs like a champ (as a matter of fact, I'm typing this on it).
If you feel like splurging out a little bit to upgrade the T410, the 640M is highly recommended. While its just barely above the 580, the price difference is negligable.
(I run W11 and OSX Sequioa on it atm)
https://i.ibb.co/RGWhynd3/IMG-20260106-175311.jpg
FORUM warning:
Picture(s) WAY too big, tags removed.
Please read the Forum Rules, especially Section 5: viewtopic.php?f=16&t=14339
FORUM warning:
W530 3940xm/32gb/520/240/240gb ssd, FHD
T410 w. I7-640m, 8GB, 240+128gb ssd hd, 1440x900
X61 w. T7500, 8GB, 240gb ssd, 1400x1050
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
WTB] [CAN-ON] X230 Motherboard with i7-3612QE (35W Quad Core)
by X230X220 » Mon Jan 26, 2026 7:35 am » in Marketplace - Forum Members only - 0 Replies
- 4112 Views
Last post by X230X220
Possible Upgrades for a T480s ?
by MortacioRatio » Sun Nov 16, 2025 8:24 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 6071 Views
Mon Nov 17, 2025 1:18 pm
Is it possible to get UDMA on a 760LD with Win98 SE ?
by aka_mgr » Sat Mar 14, 2026 4:56 pm » in ThinkPad Legacy Hardware - 1 Replies
- 1198 Views
Sun Mar 15, 2026 2:56 am
T410 cannot boot when assembled.
by phinktad » Sat Nov 29, 2025 11:50 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 9179 Views
Mon Dec 01, 2025 2:57 am
Users browsing this forum: No registered users and 39 guests
