R400 Fingerprint Drivers
R400/R500 Series
CrazyTPFan
#1 Post by CrazyTPFan » Sat Oct 13, 2018 11:48 am
Hi all, I installed Windows 10 not so long ago and everything is going well. But, I went to go install the fingerprint reader drivers on Windows 10 and the drivers said that it wasn't compatible with my OS. The drivers I downloaded are for Windows 7 (64-bit) and I thought that they would work with Windows 10. I guess I was wrong :( but, if anyone can point me in the right direction please do so. Thanks!
Screamer
Re: R400 Fingerprint Drivers
#2 Post by Screamer » Sat Oct 13, 2018 12:06 pm
Your R400 uses the AuthenTec AES2810 fingerprint reader, right? If it is, this is the driver that you should be looking for.
CrazyTPFan
#3 Post by CrazyTPFan » Sat Oct 13, 2018 12:32 pm
@Screamer Thank you, I didn't think that the Dell drivers would work after looking at a post on lenovo's forum.
mitchm
#4 Post by mitchm » Mon Jun 07, 2021 8:58 am
I can confirm, that the driver works.
You have to unzip the package, go to the device manager, select the fingerprint sensor and update the driver
Return to “ThinkPad R400/R500 Series”
