Finally got rid of Internet Explorer
A few days ago IE11 died on my desktop.
IE11 came up with only a white screen, nothing else. Nothing I did could get it to work again!
Since there is no UNinstall for this piece of crap, I manually deleted everything I could find on the drive.
Only 2 files refused to be deleted: ieproxy.dll (used in Windows Explorer) and sqmapi.dll (used in COM Surrogate, whatever that is).
Rebooted and only one (temporary) small side-effect was noted: the programs that were pinned to my Start Menu had to be re-pinned, but that was all.
After some trial and error I found a super-fast, until then unknown to me browser: Slimjet.
I only used IE11 to listen to one 24/7 classical music website: https://www.classicfm.com/radio/player/
To listen to it, just find ANY area-code (like Zip-code) in the UK.
IE11 sometimes took up to a minute to finally get going and had the bad habit of conking out at the most inopportune moments, after which a browser restart was needed.
NO MORE IE11 CRAP!
This Slimjet browser starts in seconds and has not failed me once in over a week now.
It is based on the free Chromium.
Highly recommended!
NO MORE IE11 CRAP!
Highly recommended!
Re: Finally got rid of Internet Explorer
A COM surrogate emulates an RS232 COM port by devices that still rely on that transmission protocol.
I use it extensively for programming amateur radios as they apparently haven't caught up with the 21st century yet.
They use USB ports but the radio thinks it's plugged in to a COM port.
Did you download the 32 bit or 64 bit version?
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
32-bit Slimjet even though my W7-Pro OS is 64-bit.
The Pale Moon browser that I use for everything else, is also 32-bit.
Faster, less "accident-prone" and less RAM-consuming than their 64-bit versions.
Cigarguy
Thanks for sharing that classical music link RBS.
Puppy
No, COM surrogate is a host process for COM Objects (COmponent Model objects) that is something like more advanced DLLs. It does not have anything with COM (RS 232 serial port) or Internet Explorer. It is generic system feature.
Unfortunately, you replaced the IE11 with even worse [censored] = anything WebKit based. It is slow and very resource hungry.
ThinkPad (1992 - 2012): R51, X31, X220
Huawei MateBook 13
Huawei MateBook 13
Internet Explorer is by far the most keyboard-friendly browser. It's my preferred browser for that reason alone. Opera is a distant second.
Just reinstall it: https://support.microsoft.com/en-us/hel ... -installerRealBlackStuff wrote: ↑Mon Oct 15, 2018 10:07 amA few days ago IE11 died on my desktop.
Dell Latitude 7370 (QHD+, 2.84lb); HP Pavilion x2 12-b096ms (FHD+, 3.14lb); Microsoft Surface 3 (FHD+, 2.00lb);
HP Z440 (Xeon E5-1630 v3); Dell OptiPlex 5040 SFF (Core i5-6600), OptiPlex XE2 (Core i7-4770S)
Acer ET322QK, T272HUL; Crossover 404K; QNIX QHD2410R; Seiki Pro SM40UNP
I had already tried that, but it did not work.
It was saying something like I already had a newer version, so that this could not be installed. What BS!
Since I didn't want IE anymore anyway, I couldn't care less.
Good riddance to that POS piece of slow bloatware!
Puppy wrote: ↑Mon Oct 15, 2018 6:06 pmNo, COM surrogate is a host process for COM Objects (COmponent Model objects) that is something like more advanced DLLs. It does not have anything with COM (RS 232 serial port) or Internet Explorer. It is generic system feature.
Thanks for the clarification. That was not correctly explained to me in the past when I asked about it on a communications forum.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Not sure where you get your info from, but that's totally wrong!
Here's a picture of some browser comparisons:
Some more modern browsers:
The Slimjet browser has 6 processes but uses only 107.5MB memory and NO WebKit!
That is lower than ANY of the other browsers!
I installed Slimjet on my Z60m running XP and it flies. It handles the modern web while being lean enough to operate on Pentium M. Thanks RBS
sent from my iPhone
Cigarguy
Got me curious with Slimjet. Will give it a try. Stupid me, switched from Firefox to Chrome.
Slimjet is Chromium based browser, 64-bit version for Windows is also available and Portable version is offered as well. Never heard of it before, but decided to give it a try. Imported all the bookmarks and settings from Chrome and got it ready for work. It outperforms Chrome and definitely use less memory and cpu resources at the same time. It also supports Chrome Themes, has built-in ad-blocker and YouTube download tool and supports all screen resolutions for YouTube videos unlike Firefox. Adobe Reader extension works by default, just like with Chrome. You should still disable "Continue running background apps when Slimjet is closed" and "Send anonymous usage statistics to help improve Slimjet" in Settings, just like in Chrome. And yes, Software Reporter Tool is still there, so you will have to deal with it. Procedure for disabling this cpu killing piece of crap is the same, instructions could be find here:
https://www.thewindowsclub.com/disable- ... orter-tool
Overall experience is like you're using super-fast and resource-saving version of Chrome. Slimjet is everything Chrome should have been. My Chrome is going to trash bin, finally. In fact, this post was written using Slimjet
Thanks RBS, great find.
Installed it on my T43pSF, quite pleased so far.
Thanks, RBS...
Thanks, RBS...
Tasurinchi
- Moderator
I was following some of the Chromium branches in the past but somehow totally missed this... Thanks for sharing!RealBlackStuff wrote: ↑Mon Oct 15, 2018 10:07 amThis Slimjet browser starts in seconds and has not failed me once in over a week now.
CrazyTPFan
Internet Explorer is a garbage browser to be using in 2018 but, I guess it could still be used if really needed.
This past week, a website I use extremely often no longer loads in IE. Another site I use a lot also started to not load images properly, in both Opera and IE. I was forced to look for an alternative and didn't think of Edge because I had ruled it out >3 years ago. But then I searched for "best browsers for Windows 10" and one of the articles mentioned that Edge was the fastest. Since Windows 10 already had Edge preinstalled I gave it another try. I first looked through the settings menu and was delighted that Edge is now more keyboard-friendly. Especially important to me is a keyboard shortcut to the bookmarks, which Edge didn't have before. There are also some new settings that I like. Both the abovementioned websites work fine. So I think I am switching to Edge, after using mainly IE for almost two decades (before IE it was Netscape). I'll uninstall Opera, but leave IE alone since it's good to have a backup browser.pianowizard wrote: ↑Tue Oct 16, 2018 7:38 amInternet Explorer is by far the most keyboard-friendly browser. It's my preferred browser for that reason alone. Opera is a distant second.
UPDATE: I just tried Slimjet 10 on an 11-year-old Dell OptiPlex 330 desktop with a Pentium E2180 CPU, just 1GB of PC2-5300 RAM, and running Vista Business 32bit. I was impressed that this browser works so well on such an old, basic system. Thanks RealBlackStuff for discovering it!
julia
- **SENIOR** Member
Here's another great 24/7 classical music station. KUSC. The link is www.kusc.org. There's also an app you can put on your phone.
IBM PC Convertible
Thinkpad 386-SLX (one-off prototype sold by IBM)
T30, T60, X220
T30, T60, X220
Cigarguy
Thank you. Will check it out.julia wrote: ↑Wed Feb 20, 2019 9:29 pmHere's another great 24/7 classical music station. KUSC. The link is www.kusc.org. There's also an app you can put on your phone.
Got a 600E, but I have some questions about it
by khozmos » Thu Jan 22, 2026 10:36 am » in ThinkPad Legacy Hardware - 3 Replies
- 4119 Views
Last post by khozmos
Thu Jan 22, 2026 4:46 pm
Help, got a weird machine
by Danny1984! » Tue Feb 10, 2026 8:27 am » in ThinkPad T430-T495 / T530-T590 Series - 10 Replies
- 4591 Views
Last post by Danny1984!
Fri Feb 13, 2026 10:06 am
