I teach 3rd grade and have been buying used 131e units. They looked so rugged I thought they'd replace my ancient Samsungs. But when they are dropped, the screen hinge screws just pull out of their receptacles because the plastic cracks. Not a hard drop either. Any ideas? I'm about to JB Weld the suckers shut in frustration so any help would be appreciated.
Thanks,
David
X131e hinges fragile
dwilsonfl
Vocavit autem servirent
Thinkpad4by3
Re: X131e hinges fragile
Well welcome to cheap laptop syndrome. All cheap laptops have bad hinges. What I'd do right now is replace all the units with the fragile hinges with good parts, and then everything else squirt the [censored] out of it with JB weld or some other type of strong epoxy to support the hinge.
Intel 3946ABG on my ThinkPad x131e is not being detected
by whitepainted » Mon Dec 15, 2025 9:23 am » in ThinkPad X100e/X120e/X130e/X140e Series - 2 Replies
- 4504 Views
Tue Dec 16, 2025 1:57 am
I thought 4:3 T61 were supposed to have good hinges
by dcfbf » Mon Dec 01, 2025 5:42 pm » in ThinkPad T60/T61 Series - 5 Replies
- 7709 Views
Last post by ajkula66
Wed Dec 03, 2025 7:38 am
Users browsing this forum: No registered users and 575 guests
