Thinkpad x1 extreme battery life
crypto60
#1 Post by crypto60 » Thu Nov 01, 2018 10:46 am
One of the downsides of the x1 extreme is that it only has the integrated battery, since it has the higher draw CPUs and fancy screens Battery life isn’t that great. I am going to start undervaluing the cpu and such but besides the very obvious recommendations anybody find any particular tips to improve battery life on these machines
Thinkpad4by3
Re: Thinkpad x1 extreme battery life
#2 Post by Thinkpad4by3 » Thu Nov 01, 2018 11:40 am
If you aren't doing anything graphics intensive you might want to try seeing if you can switch to integrated graphics.
MrMojo
#3 Post by MrMojo » Wed Dec 18, 2019 11:18 am
It depends on what you're doing.
I have the X1EG1 with 4k screen and don't do any gaming as it's used more for business and for personal usage. Reduce the screen brightness to ~50%, turn off all background activities not needed and adjust the power options to your needs such as power consumption instead of performance and you should get decent battery life ~5-7 hours which isn't bad for a laptop with a 4K screen.
If you do more graphics intensive work or even some gaming, then the battery life will be affected more. The X1E isn't meant for gaming, though.
ThinkPad
#4 Post by ThinkPad » Mon Apr 20, 2020 8:37 pm
I have been using my Gen1 with 4k for over a year, and the battery is not great no matter what is tweaked. The HD screen may be more efficient but I have just accepted it. Good thing it charges quick and always keep the charger around.
RIP-Thinkpad T41 2379 DJU
Users browsing this forum: No registered users and 40 guests
