Ultranav driver for W7 (R500)
R400/R500 Series
wujstefan
#1 Post by wujstefan » Thu Nov 01, 2018 3:29 pm
Honestly I personally hate what Lenovo does with "updating" the drivers. All in all those systems worked perfectly fine when on old drivers, and now it's a pain in the thing.
I have installed all the drivers needed for everyday work (of course, needed to install old on-screen display drivers since the new ones do not display anything).
The thing is, I wanted to make the middle-trackpoint button work. And so I installed the ultranav driver. Result? Does not work, there is an ultranav icon under "mouse" tab in system properties, but it is grayed out.
So I decided to update ultranav utility. Result? Both touchpad and trackpoint stopped working, at all.
And so I installed old ultranav utility first. After fn+F8 combination it popped info "ultranav device not installed". Well, true.
Fo I tried to install new ultranav driver now. "No synaptics device present".
Tried with lenovo system update (the driver only). Middle button does not (still) work, but all the other functions do. However, "Ultranav" options in mouse settings are grayed out, and when trying to turn off touchpad, it turns off both touchpad and trackpoint; and this action is irreversible.
Do you guys have it working under W7? Is there some software-catch one should know like with the function keys functionality?
(stable under reduction)
TPFanatic
Re: Ultranav driver for W7 (R500)
#2 Post by TPFanatic » Thu Nov 01, 2018 5:09 pm
Even though the Trackpoint is by Synaptics, the R500 and some X300 series use ALPS touchpads so a different Ultranav driver is required.
R500 Ultranav Driver 64 bit: https://support.lenovo.com/bg/es/downloads/ds013749
R500 Ultranav Driver 32 bit: https://support.lenovo.com/us/en/downloads/ds013899
In my experience the ALPS touchpad actually tracks better and feels like the Synaptics touchpad if you use the basic Windows pointing device driver and do not install the above drivers. How to get around the missing Trackpoint functionality? Install the Trackpoint Driver used in Trackpoint only systems such as the X60, X200, etc.
X200 Trackpoint Drive 64 bit: https://support.lenovo.com/bg/es/downloads/ds003654
I have not tested this combination though and I no longer have an R500.
Ultimately to get the best touchpad in an R500 you'd have to physically replace it with a Synaptics out of any T400, R400, or T500 palmrest.
wujstefan
#3 Post by wujstefan » Fri Nov 02, 2018 11:45 am
This one results in non-working touchpad and trackpoint. Not working at all.
And this one just pumps out message "you can't install this driver on non-trackpoint system".
#4 Post by RealBlackStuff » Fri Nov 02, 2018 11:58 am
This one works with R400, T400, T500, W500 and probably also R500: https://support.lenovo.com/us/en/downloads/ds019164
wujstefan
#5 Post by wujstefan » Fri Nov 02, 2018 12:09 pm
"Synaptics device not found".
Weirdo. I have tried lots and lots of drivers already
#6 Post by RealBlackStuff » Fri Nov 02, 2018 1:08 pm
In Device Manager/Properties/Details, what is the Hardware ID?
Get more ID info with this: http://www.zhangduo.com/udi.html
wujstefan
#7 Post by wujstefan » Fri Nov 02, 2018 2:06 pm
ACPI/LEN0006
EDIT: I was digging for a proper driver, but it does not seem like easy task. I have found a few, but none loads properly.
#8 Post by RealBlackStuff » Fri Nov 02, 2018 2:23 pm
That's Alps.
There's a bunch of them here: https://drivers.softpedia.com/get/KEYBO ... ws-7.shtml
But that's the end for me.
wujstefan
#9 Post by wujstefan » Fri Nov 02, 2018 2:34 pm
That's Alps.
And thank you very much. This is still not working, however.
I have some couple of ideas here. Will try them out and share the effect. Hoping to get it working properly.
TPFanatic
#10 Post by TPFanatic » Sat Nov 03, 2018 9:10 am
Just an idea, try it with a different keyboard.
wujstefan
#11 Post by wujstefan » Sun Nov 11, 2018 12:21 pm
This was close! It was... palmrest for some reason! Swapped palmrest, everything runs great.
Return to “ThinkPad R400/R500 Series”
