I have a first release first gen Fat PlayStation 3, So it had all the memory card slots and 4 USB ports and also plays PSone, PS2 and PS3 game discs. The console been sitting for years and it would power on but with in 3 seconds it would power green then 1 yellow then flashing red. So I stuck it on a shelf and it been sitting ever since and had a new PS3 Slim 2nd gen I got new at the time. I today saw it sitting on the shelf and just to check if it would do anything different I powered It on with same problem as before. So I took the entire system apart removing the warranty void sticker and just going to check inside as I use to fix IBM PCs. As suspected the thermal paste was dry and hard as a rock. Took sometime to clean off the 2 chips that seem to have the RLOD or YLOD problems with these PS3s. Once cleaned off and cleaned with alcohol I used my mini hot air gun and lightly heated the two chips with lightly pushing on them to make sure the contacts touch if that was the problem.
After letting it cool, I cleaned the chips again and added my considered best thermal paste "Artic Silver 5" to the chips heat sinks and put everything back together and doing a test power on before putting the lid on the console and powered it on and a solid green light came on. I fully put the case back together and hooked it up to the tv and it works perfectly and even tested out a PSone, PS2 and PS3 games disc in the machine and it played them fine. My only grief about this original fat PS3 is that the fan sounds very loud, a lot more louder them my IBM server tower. I don't know if this was a design flaw but these PS3s seemed to get too hot, As for the air outtake, it isn't blowing any hot air out but just a light warmth. As of right now I have it running and getting updates and the fan sound like it is in the 2nd to last fan spin with no decrease or increase in fan speed.
Sony PlayStation 3 first Gen I saved.
ThinkPad560X
IBM: 760XD,770Z,600X,240,560X,560Z,570,380Z,390X,i1200,i1400,
A22m,A22e,A30,G40,R31,R40,R50,R60,R61,R400,R500,
T20,T23,T30,T40,T43,T60,T61,T400,T400s,T500,W500,W700,
X21,X30,X41,X41T,X60,X60T,X200,X200T,X300,X120e,Z60m,Z61t
T410|T510 to T480|T580
L440|L450 to L480|L580
X220 - X280
X220 - X280
First steps after buying a used Thinkpad
by Thinkpad2024 » Tue Nov 18, 2025 3:55 pm » in ** HOW TOs & FAQs ** - 3 Replies
- 9499 Views
Last post by dcfbf
Tue Nov 18, 2025 8:26 pm
I just purchased my first Thinkpad
by Carey5831 » Tue Dec 09, 2025 3:34 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 4746 Views
Last post by teamde78
Mon Dec 29, 2025 12:12 pm
- 14109 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8991 Views
Sun Oct 26, 2025 12:57 am
