SK-8855 keyboard module swap?
RichardG867
#1 Post by RichardG867 » Mon Jan 14, 2019 9:09 am
Hey everyone,
I'm considering getting a SK-8855 keyboard, however it doesn't appear to exist in my local layout (Brazilian), probably due to the registry editing required to get one of the keys working. I do however have a T410 keyboard with that layout, and I was wondering if I could swap the keyboard module on a SK-8855?
The registry editing is not a concern as I would use the SK-8855 as the only keyboard on a single system.
ztof
Re: SK-8855 keyboard module swap?
#2 Post by ztof » Sun Feb 24, 2019 3:30 am
Yep 100% compatible with keyboards from T410/T510/X220/T420/T520.
I've done it on my SK-8855, I bought the SK-8855 with French AZERTY layout and then replaced by a T410 keyboard with QWERTZ Swiss layout.
Just like Brazilian layout, SK-8855 is impossible to find with QWERTZ-Swiss layout ;)
T430-Classic-Keyboard HD+ Glossy LCD| X230-Classic-Keyboard IPS LCD| SK855 & SK-8835 keyboards | IBM Model M keyboard
artic_squirrel
#3 Post by artic_squirrel » Fri Mar 01, 2019 4:26 am
I do not understand the hype with this keyboard. As soon as I type on it, I want to go back to the x61 with NMB keyboard. The buttons of the trackpoint are too flat .
Thinkpad4by3
#4 Post by Thinkpad4by3 » Fri Mar 01, 2019 10:18 am
1: I go back to my full height travel mechanical keyboard and a mouse.
2: They didn't make the 6x series machine keyboard in a USB form.
3: If you want the higher TP buttons, get the IBM version of this keyboard with the T4x buttons.
ztof
#5 Post by ztof » Fri Mar 01, 2019 11:41 am
Well, SK-8855 is just as bad or as good as the X220 keyboard...
If you don't like the default keyboard in it (maybe a Chicony or Alps), then just replace it with a X220 NMB keyboard ;)
Users browsing this forum: No registered users and 50 guests
