recently I bought one Lenovo 3000 N100 (without a battery), and have following issue with it: when it remains longer disconnected from the power supply, it doesn't start at first button press. At the second one it starts, but says "Time and date are not set, CMOS checksum is bad". When I go to BIOS, it says "01/01/2015". I suppose, the BIOS battery is empty. Is it possible to replace CMOS battery (like in thinkpads)?
regards,
Andrey
3000 N100 - date and time are getting reset, CMOS battery empty?
BigCatAndy
- in use -
(1) TP R61i Frankepad - 4 GB / C2D T9500 / 180 GB SSD / UXGA display
(2) Lenovo 3000 N200 - 2 GB / C2D T7300 / 160 GB
(3) TP T450s
- in museum -
IBM 600x, IBM TP T43p, Lenovo TP Z61t, Lenovo TP X60 Tablet
(3) TP T450s
- in museum -
Re: 3000 N100 - date and time are getting reset, CMOS battery empty?
Took a quick look at the N100 HMM https://download.lenovo.com/ibmdl/pub/p ... 553_03.pdf but I can't seem to find a replaceable CMOS battery. It's possible that the CMOS battery is a rechargeable one that's soldered to the system board.
Confusingly, the Symptom-to-FRU Index mentions:
It's likely that the main battery is needed to keep charging the backup one in order to keep the date and time.
#1 proves that there's a rechargeable backup battery, but #2 implies a removable battery but is never mentioned in the disassembly section.0270
Real time clock error
1. Charge the backup battery for more
than 8 hours by connecting the ac
adapter.
2. Replace the backup battery and run BIOS
Setup Utility to reset the time and date.
BigCatAndy
Thanks you very much for the hint. I found on the Internet, the type of battery - fixed or replaceable - depends on the type of the laptop.axur-delmeria wrote: ↑Sat May 18, 2019 2:14 amTook a quick look at the N100 HMM https://download.lenovo.com/ibmdl/pub/p ... 553_03.pdf but I can't seem to find a replaceable CMOS battery. It's possible that the CMOS battery is a rechargeable one that's soldered to the system board.
adapter.
Setup Utility to reset the time and date.![]()
It's likely that the main battery is needed to keep charging the backup one in order to keep the date and time.![]()
Going to put the laptop on the power over the night.
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
BigCatAndy
Update: CMOS battery keeps the date and time after keeping my laptop on the AC power for 8-10 hours.BigCatAndy wrote: ↑Sat May 18, 2019 9:50 amThanks you very much for the hint. I found on the Internet, the type of battery - fixed or replaceable - depends on the type of the laptop.
Regards,
Andrey
Andrey
- in use -
(3) TP T450s
- in museum -
(3) TP T450s
- in museum -
[WTB] VINTAGE IBM THINKPAD 3xx 7xx hard drive caddy empty
by igtoth » Wed Apr 08, 2026 6:10 pm » in Marketplace - Forum Members only - 0 Replies
- 870 Views
Last post by igtoth
FS: NOS Frankenpad T61p motherboard 44c3926 NEW 2011 date NVIDIA fx570m fits 14.1 and 15 4:3 t60, t61
by andre#4 » Fri Feb 06, 2026 1:58 pm » in Marketplace - Forum Members only - 1 Replies
- 4011 Views
Last post by andre#4
Mon Feb 09, 2026 9:34 pm
Looking for a CMOS battery for Lenovo X1 tablet gen 3
by babblefish » Thu Feb 05, 2026 4:12 am » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 12 Replies
- 6959 Views
Last post by dcfbf
Mon Feb 09, 2026 7:22 pm
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 9308 Views
Sun Nov 02, 2025 2:30 pm
