LF: Swiss Keyboard for t410 t420 x220
I need it for x220 but should be the same as t410, t420, t510, t520, w510, w520
Good condition is preferred
X61 (T9300, 8gb RAM, 120gb SSD, LED SXGA+, integrated webcam, invisible touchpad, modded battery etc.)
Re: LF: Swiss Keyboard for t410 t420 x220
German is the same, unless you need a Swiss-French keyboard.
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Tasurinchi
- Moderator
Not really, there are few differences, some of them very annoying...German is the same, unless you need a Swiss-French keyboard.
To the OP, I got many good keyboard out of eBay, mostly overseas (=China) sellers, shipment takes longer of course, but few sellers based in HK or Shenzen manage to send packages that arrive in less than 10 days...
I see it has a couple of more characters on the umlaut keys and the @ is moved from the Q key.
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
Yes, I know the German keyboard and the difference is essential for one used to Swiss keyboard
Yep, I know what you means, as I'm using exclusively the Swiss layout. I'm French but totally converted to Swiss layout since several years (better than AZERTY for coding, and still has french accent letters). And sometimes it's hard to find one on the web...
I've bought one keyboard in Belgium (a guy who bought a used Thinkpad from Luxembourg), another on eBay Italy.
And the last two I've found (for my T430 and SK8855 USB ultranav) was by searching directly on eBay Switzerland (ebay.ch), as some Swiss listings are not taken back on other eBay websites such as ebay.fr or ebay.de
Note: if it might help your searches, the default keyboard layout used in Luxembourg is also Swiss French
T430-Classic-Keyboard HD+ Glossy LCD| X230-Classic-Keyboard IPS LCD| SK855 & SK-8835 keyboards | IBM Model M keyboard
Virtualization on T420
by Berator » Sat Nov 22, 2025 10:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 7415 Views
Sun Nov 23, 2025 11:56 am
- 5 Replies
- 7637 Views
Last post by rssb
Fri May 01, 2026 9:43 pm
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 9 Replies
- 11567 Views
Last post by PhoenixR
Mon Apr 27, 2026 1:35 am
T420 Lid Sensor Trigger Location? (WARNING: PICS)
by T_B » Fri Jan 16, 2026 11:08 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 2 Replies
- 7230 Views
Last post by T_B
Mon Jan 19, 2026 11:24 pm
Users browsing this forum: No registered users and 78 guests
