SL510 upgrade to ssd
From what I've read, the SL510 *can* be upgraded to an SSD. I just did a clean install of windows 7 64 bit, cloned the drive with macrium reflect to a Kingston A400 SSD - I can see everything on the drive if I plug it into a usb-SATA adapter. However, the bios refuses to see it. It lists HDD0, but there is no name beside it, and if I try to boot from it, it just doesn't acknowledge it. The drivers for the intel chipset are updated, the bios is updated - it's as if it doesn't exist.
I'm trying to upgrade this laptop for somone - I've done other Lenovo laptops, but no luck on this one.
Any Ideas?
Any Ideas?
Re: SL510 upgrade to ssd
Depending on SATA settings in BIOS, change it from Compatible to AHCI.
Did you clone the boot partitions as well?
If not, redo the cloning including those partitions.
It was already AHCI. I did a full clone - as I've always done before - this isn't my first rodeo. I don't know if it's something to do with the Kingston A400 SSD (I've tried *2* of them). I can see everything on them when in a an external enclosure, but plug them into the drive bay and *poof* nothing. The Bios doesn't see them. The Windows install CD *sees* them, but can't install because the bios doesn't see them.
Did it pick up the original hard drive?
Dell Precision 7540 - 16GB DDR4, i7 9750H, RTX 3000, 500GB SSD, 60hz 1080p IPS
Dell Precision M4800 - 32GB, i7 4810MQ, WX4150, 500GB SSD, 1TB HDD, 120HZ 1080p with BenQ SW240
HP Zbook 15 G2 - 16GB, i7 4710MQ, Nvidia M2000M, 500GB SSD, and 2TB HDD, 4G LTE LT4112
Lenovo ThinkPad T61 - Win7Pro 64bit
Oh, it does that no problem - slap it back in, and it reboots perfectly. I'm starting to wonder if it's the Kingston A400 line that 's the issue.
Kind of annoying if it is, means I need to buy another drive
Yup....the SL510 doesn't get the drive ID info from the Kingston A400 - I just bought a Crucial MX500. First thing I did was slap it in, boot up to bios - and there it is, an identified drive.
The A400 was fine in some newer models - I guess it just can't talk to the older hardware
Hey hello, the same problem but in 2024 trying to give a old laptop to my grandma, it's just anoying, i tried everything with the kingston a400 480gb but nothing worked, like if i doesn't now anything about computers. I was mad but i'm going to buy another ssd just to try to solve the darn problem, trying with a cheap crucial ssd to look if that works. just thank you for posting this, imagine that i'm from Argentina (so far away) and you just give me a chance to not throw a laptop in a box xd. Just thank you, i dont think you are gonna read it but it was so helpful, i'm gonna post updates about this so maybe someone read it and they know that it can be solved (i dont really know).
Upgrade SSD & RAM on New ThinkPad While Keeping Warranty – Who Tried It?
by marcusfrank » Wed Nov 26, 2025 8:24 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 12488 Views
Fri Nov 28, 2025 4:18 am
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 8518 Views
Sun Nov 02, 2025 2:30 pm
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7585 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
SOLD: thinkpad X61, T8300, 8GB. SSD, Atheros AR938 - EU ONLY
by zz7 » Wed Oct 29, 2025 10:57 am » in Marketplace - Forum Members only - 0 Replies
- 6928 Views
Last post by zz7
