R40e won't start
R40e won't start
Hi everyone, yesterday I bought an IBM ThinkPad R40e with 256MB of RAM. I try to turn it on and it tells me that the following file is missing or damaged: \windows\system32\config\system.
I should reinstall windows or install a light version of linux like puppy linux or Tiny Core Linux.Do you have some tutorial to do it from USB? I tried to do it but it doesn't recognize me the USB keys and when I try to boot from usb it tells me the missing operating system.
tfflivemb2
- Moderator Emeritus
Re: R40e won't start
Do you have an image on the USB? If so, is the USB bootable? I have been using "Rufus Portable" lately to create bootable USB Drives. You can also check the Marketplace, where there is a post from a user that has a ton of recovery disks available. Not sure about the R40e though.
PS
Please update your location, per forum rules. Thanks!
PS
I have a Windows XP iso image but the bios doesn't recognize the os. In the bios setup the USB Boot is enabled. So I don't know I can do it
tfflivemb2
If you have the XP ISO on a computer, you can use a program like Rufus Portable to properly burn the ISO to your USB, to make it bootable.
The bios doesn't differentiate between the different OS's, its just not seeing a boo table device.
The other option is to burn the XP ISO file to a cd.
The problem can be the fact that the usb is also a micro usb pen for mobile device. I think that this kind of stuff are not recognized by old hardware. Do you that I may change the usb pen drive? I have also an 16GB 3.0 USB.
Update. I used the 3.0 usb and the bios recognize it. But when I boot the usb the result is:
Missing operating system.
Operating System not found
I used a live version of Puppy Linux so I restored windows xp and now all works. Thank you
- 2 Replies
- 19180 Views
Last post by mvaudio
Sun Nov 02, 2025 9:57 am
T480 won't boot - power button just flashes.
by kae2020 » Fri Dec 05, 2025 11:20 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 11674 Views
Last post by kae2020
Sun Dec 07, 2025 2:03 pm
- 1 Replies
- 4990 Views
Last post by ogopogo
Thu Feb 12, 2026 5:07 pm
X1 tablet gen 3 won't boot after SSD replacement
by babblefish » Thu Feb 19, 2026 10:22 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 7 Replies
- 4404 Views
Last post by babblefish
Fri Feb 20, 2026 7:44 am
