Compatible DVD drives for Ultrabase Series 3
Tetsuo1981
Hi all
New to the forum and about to receive my first ever ThinkPad, an old X230 with i5 3380m 2.9ghz. Excited to get it up and running and customizer and thought this looked like a useful forum.
Anyway, onto my actual question. I quite like the idea of the Ultrabase Series 3 for added functionality but am stumped as to which dvd drive I should get to put in it. Can anyone point me in the direction of a compatibility list? Also does it HAVE to be a Lenovo drive or can I put any 9.5mm sata disc drive in the slot?
Any help would be appreciated. Thanks for having me
Re: Compatible DVD drives for Ultrabase Series 3
Welcome to the forum.
Just get an Ultrabase that comes with the DVD drive installed already; on the second-hand market most of them do.
Tetsuo1981
Cheers for the quick reply.
I've not had much joy on that front, ebay UK has a few but they're either really expensive or coming from Germany. Loads on there without drives which got me to thinking of just grabbing a 2nd hand Lenovo one or a generic one to stick in it. I'll have to keep my eyes peeled.
I have an X230 and Ultrabase in the basement here. You need the base with DVD to install an OS on that machine with a CD/DVD. The DVD drive is a UJ8C2 FRU P/N 45N7457.
The X230 is not that old. Mine is running an advanced Insider version of Windows 10. Nice machine
Tetsuo1981 wrote: ↑Wed Nov 06, 2019 5:52 pmI've not had much joy on that front, ebay UK has a few but they're either really expensive or coming from Germany.
https://www.ebay.co.uk/itm/IBM-Lenovo-T ... 3177805928
This is literally the first result when I search "Ultrabase Series 3" on Ebay UK...
Tetsuo1981
Stone me, I must have gone ebay blind!! How did I miss that??dr_st wrote: ↑Wed Nov 06, 2019 11:50 pmTetsuo1981 wrote: ↑Wed Nov 06, 2019 5:52 pmI've not had much joy on that front, ebay UK has a few but they're either really expensive or coming from Germany.![]()
Tetsuo1981
Thanks for that. I'm really looking forward to using it when it comes, planning the usual upgrades (IPS screen, ssd and msata and max ram). Considering my desktop is an old dell core 2 duo I'm excited for something a bit more modern!!jdhurst wrote: ↑Wed Nov 06, 2019 7:45 pmI have an X230 and Ultrabase in the basement here. You need the base with DVD to install an OS on that machine with a CD/DVD. The DVD drive is a UJ8C2 FRU P/N 45N7457.
onespeedbiker
Something to keep in mind. When you install the DVD player, you will notice it until does not show up in the device manager, as by default it is not enabled. In order to enable the DVD player, you must either change something in the power management, or press the DVD button twice (a popup window advise you of this). I understand power management is important to battery life, but the vast majority of people using a port replicator, aka docking station, will be using a power supply, so this always seemed quite pointless to me. Regardless, a docking station w/DVD is a great upgrade for an x230.
Pareto Optimal
Wont any Lenovo Slim Line DVD drive fit and any other one that is as slim? There's no bezel required for it to fit. I have an old IBM and a Lenovo one and a Dell, I think or no brand slot load that looks like it could fit.
Alternatively, couldn't you use a USB to SATA 7+6 pin cable to connect an internal DVD drive externally to any of the laptop's USB ports?
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8804 Views
Sun Oct 26, 2025 12:57 am
Compatible SSD’s and Recommendations for a Thinkpad 770X
by NineVolcanic » Sun Mar 22, 2026 5:01 pm » in ThinkPad Legacy Hardware - 5 Replies
- 1485 Views
Last post by NineVolcanic
Sun Mar 29, 2026 8:35 am
- 10 Replies
- 3212 Views
Last post by tpribors
Fri Apr 17, 2026 12:52 pm
WTB: 770Z with DVD-ROM drive
by KylesDigitalLab » Sat Jan 31, 2026 5:55 pm » in Marketplace - Forum Members only - 0 Replies
- 3028 Views
Last post by KylesDigitalLab
Users browsing this forum: No registered users and 68 guests
