FRU P/N repository of thinkpad parts
I have a whole great set of CD/DVD/Bluray drives from thinkpads, but I cant find any information about FRU-to-thinkpad-model compatibility. Is there such site / document that would potentially allow recognition of drives I have in my stock?
(stable under reduction)
Re: FRU P/N repository of thinkpad parts
Does Thinkwiki not provide enough info for your needs?
Nope!
I've got more than 40 different FRUs, lots of them are hard to determine which kind of UB are they. FRUs be my guide!
iamdmc
thinkpads.org/fru used to work in 2019 but it's down now
https://libthinkpad.github.io/fru/ is still up though!
last resource: https://support.lenovo.com/us/en/partslookup but not as 'readable' sometimes in my experience
ThinkPad X1C gen10 (2023)
i5-1235U | 16GB RAM | 2TB Samsung 990 Pro | QHD OLED
The X61 is dead... long live the X61
Past * current IBM (&lenovo) ThinkPads: X1C12, X1C10 P14s gen2, T480s, T450s, X250, X230, X220, X300, T410, X61s, T60p, T41, X31, T23, A21m
cadillacmike68
Look at the wording on the drive, if it says Ultrabay Slim or Enhanced, then it-s T40-T61 era (and R, X, etc). If it says Serial Ultrabay Slim or Enhanced then its from the T400-500-440-540 (and maybe later) era,
The back end connectors are also dead giveaways.
Only 40??
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
40 types of unused FRUs. For ~300 total.
It's unfortunately not entirely truthcadillacmike68 wrote: ↑Fri Apr 03, 2020 8:26 pmLook at the wording on the drive, if it says Ultrabay Slim or Enhanced, then it-s T40-T61 era (and R, X, etc). If it says Serial Ultrabay Slim or Enhanced then its from the T400-500-440-540 (and maybe later) era,
cadillacmike68
In the T-series era, from T20 through The T--W-440/540 series there were only three physical interfaces and two heights. The Ultrabay 2000 series has a longer rounded end connector that sticks out from the end of the device. It's in T/A/R 20 and 30 series.wujstefan wrote: ↑Mon Apr 06, 2020 1:02 pm40 types of unused FRUs. For ~300 total.
It's unfortunately not entirely truthcadillacmike68 wrote: ↑Fri Apr 03, 2020 8:26 pmLook at the wording on the drive, if it says Ultrabay Slim or Enhanced, then it-s T40-T61 era (and R, X, etc). If it says Serial Ultrabay Slim or Enhanced then its from the T400-500-440-540 (and maybe later) era,![]()
The next one is the Ultrabay Slim and Enhanced. These had a connector that was flush with the back and T/R/X60 series had a plastic tip on the end to prevent them from going into the older T/R/X-40and 50 series. People cut this tab off and the drives supposedly work in the x40 and 50 series. These don't say ultrabay slim or enhanced, but it is EASY to tell what you have got, The connector is a One Part affair unlike the later ultrabay serial device. and there are two heights, slim and enhanced with the enhanced being about 2-3mm thicker.
The ultrabay serial slim and serial enhanced also have a flush connector, but if you look it, it is in Two parts. They also have a smaller square shaped tab that sticks out in the middle to prevent them from going in an older series. These are again in two heights with the enhanced being 2-3mm thicker just like the earlier series.
IBM / Lenovo source parts from many subvendors and just changing the optical drive inside from Toshiba to Panasonic to HL, etc, makes a different FRU. Firmware updates will also cause a new FRU. I've seen many DVD Multi ultrabay slim drives with a II or II after the name which tells me that it is a later revision of the first (IBM) DVD multi drives. Even what looks like the same item will have something different inside that will make it a different FRU. there is also the MFR PN same numbering style what closely follows the FRU numbering pattern.
In the end there are only those 3 connectors (3 & 1/2 with the slim T60 devices with the tab on the end) in two heights.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
Well, if there's a R61-compatible BD burner in that lot, I'd be interested.
240, 380ED, 760C, 760CD, 760E, 760EL, 760LD, 760LD, 760XD, 760XD, A30, E520, G40, I1300, P53, R31, R40, R51, R52, R61, T20, T30, T40, T41, T42, T43, T43P, T60, T61, T400, T410, T420, T430, T460, X1C2, X30, X40, X220, X301 and on, and on, and on...
cadillacmike68
R61 takes the Ultrabay Enhanced taller 12.7mm drives.
There is one, PRICEY BRD that fits it, but I can't find one on ebay. The rest of the x60/61 systems have Ultrabay Slim (9.5mm high) and to my knowledge there was never a PATA BRD in 9.5mm high size.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
FS: Ultrabay Slim HD Drive Adapter FRU 62P4553 w/160GB hard drive
by PiZzA EnGiNeEr » Wed Mar 04, 2026 8:08 pm » in Marketplace - Forum Members only - 1 Replies
- 2163 Views
Last post by coolcat37
Sat Mar 21, 2026 5:31 am
WTB: T480 i7-8650u motherboard or in parts
by phobiak » Wed Apr 15, 2026 4:15 am » in Marketplace - Forum Members only - 1 Replies
- 395 Views
Wed Apr 15, 2026 5:36 am
Thinkpad Helix 2 - Old Bios (1.77) Update (2.16-2020) done ...
by friedrich-eugen » Sun Oct 26, 2025 9:31 am » in ThinkPad/Ideapad Tablets & Convertibles - 0 Replies
- 10772 Views
Last post by friedrich-eugen
Model Recommendation For A ThinkPad Newbie
by onetr » Sun Oct 26, 2025 9:39 pm » in GENERAL ThinkPad News/Comments & Questions - 4 Replies
- 7835 Views
Last post by Bionicman
Sun Nov 16, 2025 11:26 am
