Can you suggest me some camera covers? [T520/X201]
Kristian-770
#1 Post by Kristian-770 » Fri Jan 31, 2020 5:35 am
So, I would like a couple covers that work like the ThinkShutter, which these two machines are of course too old to have. I looked at the EFF (would not mind supporting a worthwhile cause) but they offer only stickers.
Anyone here familiar with a ThinkCentric retailer of laptop camera covers?
MikalE
Re: Can you suggest me some camera covers? [T520/X201]
#2 Post by MikalE » Fri Jan 31, 2020 8:06 am
Cut a small square of electrical tape. Problem solved.
I have it on all of my systems with a camera installed.
A31p P-IV 2Ghz, 2MB, 2653-R6U
T500 T9600 2055-BE9
T510 i5 4384-DV7
T510 i7 4349-A64
T16 i7 1260P 21BV000SUS
#3 Post by RealBlackStuff » Fri Jan 31, 2020 8:30 am
Or check eBay with: laptop webcam (cover,shutter)
#4 Post by dr_st » Fri Jan 31, 2020 11:44 am
These generally work well for me:
https://www.ebay.com/itm/6PCS-WebCam-Sh ... 2952493265
But you may have to mount them vertically on these Thinkpads, as the bezel isn't flat enough there.
Kristian-770
#5 Post by Kristian-770 » Sun Feb 02, 2020 3:28 pm
I'm aware of the tape solution, I just thought it would be nice with something with a red dot or whatever.
dr_st: Thanks, let me look into those.
cadillacmike68
#6 Post by cadillacmike68 » Mon Apr 06, 2020 9:43 pm
Just paint a red dot on the tape! Or use a small piece of red duct tape.
600 600X
760LD FUBARd
T41 T42 T43
T500 2
T530 W530
Radioguy
#7 Post by Radioguy » Wed Apr 08, 2020 6:13 am
STAPLES has this set on clearance, but only in stores. I think it was like $3 or so.
https://www.staples.com/staples-webcam- ... t_24338444
240, 380ED, 760C, 760CD, 760E, 760EL, 760LD, 760LD, 760XD, 760XD, A30, E520, G40, I1300, P53, R31, R40, R51, R52, R61, T20, T30, T40, T41, T42, T43, T43P, T60, T61, T400, T410, T420, T430, T460, X1C2, X30, X40, X220, X301 and on, and on, and on...
Users browsing this forum: No registered users and 120 guests
