T480 Modification with Thinkpad T25 7-Row Keyboard
LeoKim is at it again: Perfect T480 Modification with ThinkPad T25 7-Row Keyboard
theterminator93
Re: T480 Modification with Thinkpad T25 7-Row Keyboard
Well, at least it's possible - though I wish he went into more detail on how to do it for those of us without a degree in electrical engineering...
Got my T480 a few weeks ago, and I have my old T25 keyboard on hand so I guess it's time to start getting the rest of the parts on order...
The recovery sets guy
Was wondering if a CPU swap is possible instead of a keyboard swap. i.e. put a i7-8650u into a T25. i.e. if someone has the equipment and expertise to desolder and put a new one in.
Of course the BIOS has to support as well. The T480 series has been sold with 7th gen 7200u cpu etc.. That way the base, nvidia graphics , docking port are all still intact.
https://ark.intel.com/content/www/us/en ... 0-ghz.html
Both seem to have same voltage and FCBGA1356 .
ThreeIguanasPerSecond
the CPU isn't just the CPU itself for this era, it's more than that. a lot of people in the know call these new CPUs SoCs for that very reason, because it integrates a lot of components into what would be the package meant for only the CPU. they might have the same voltage and amount of solder balls, but it doesn't mean it's a straight swap with a simple UEFI modification to follow.
for example, the 8650U and the 7500U you linked has integrated chipsets. that itself is a major blockade when it comes to CPU upgrades, as it may introduce a lot of electrical signaling changes that we can't see or tell apart from doing trial and error guesses. if you were to simply switch the SoC around that has a chipset which may be different, you have to modify the UEFI as well for that to work. and modifying the UEFI to support different chipsets? that's near impossible without building an entirely new UEFI from scratch.
for the record, switching chipsets generally requires the entire motherboard to be modified too. such as the amount of layers, traces, etc. you get the idea.
"There is always you can not think of the low price." - JD.com
Thank you ThreeIguanasPerSecond, what you said makes lot of sense with the chipset etc.
Not sure if they used old chipset and designed specific motherboards, within the same series ( i.e. 20L5 ) and created a subseries within that 20L5.
on page 78 of this pdf http://psref.lenovo.com/syspool/Sys/i_pdf/ThinkPad.pdf
The model is available for sale on amazon
https://www.amazon.com/Lenovo-Thinkpad- ... B07L6RKX2Y
From a manufacturing perspective, i.e. cost of production, would lenovo go out of their way to design whole new motherboard just to sell 2 older model i5 processors ...
Hence was hoping if the 8th generation and 7th generation support or can use same chipsets interchangeably.
Again like you said if it is a whole different chipset and components & sub components and Lenovo was willing to put in the effort just to call a T470 as T480 , they must be easily capable of making the T25 keyboard fit the newer models.
I wish lenovo gave the T25 keyboard as an option for other models or atleast for one model sometime in future which can get us through another 3 years of having a good machine!.
So far the T25 is great, does most of the things, except for running VM'.s
Everybody wishes that, except brain-dead corporate execs at Lenovo apparently. Who knows, maybe one day someone will surprise us.
ThinkPad T25 ANSI US Keyboard from Amazon
by vermaden » Sun Nov 09, 2025 6:26 pm » in Thinkpad T25 Anniversary/Retro - 1 Replies
- 8212 Views
Last post by David C
Tue Jan 27, 2026 9:30 pm
T480 screen shuts off after a few seconds to a minute after starting to use it.
by FranklinHawkings » Wed Oct 22, 2025 5:26 pm » in ThinkPad T430-T495 / T530-T590 Series - 13 Replies
- 23627 Views
Sat Nov 01, 2025 12:09 am
T480 never offered update to Windows 11 24H2
by cage » Wed Nov 12, 2025 3:10 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 7007 Views
Last post by pianowizard
Wed Nov 19, 2025 9:08 pm
T480 won't boot - power button just flashes.
by kae2020 » Fri Dec 05, 2025 11:20 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 9813 Views
Last post by kae2020
Sun Dec 07, 2025 2:03 pm
