W540 screen replacement
W530/W540/W541/W550 Series
thinkreal
#1 Post by thinkreal » Fri Feb 21, 2020 7:57 am
Hello:
Just bought a used W540 and would like to replcae the FHD TN screen with an FHD IPS screen. Anyone has experience where I can buy the replacement screen?
I managed to remove the screen panel and took a few photos; not sure if it helps but would appreciate if you can tell if this is a 30 or 40 pin connector:
Thanks.
jursky
Re: W540 screen replacement
#2 Post by jursky » Mon Feb 24, 2020 6:02 pm
I am not sure but I think Lenovo didn't make FHD IPS version for W540? If I'm not mistaken, there were two options: a) FHD TN panel and b) 3k IPS panel. So if I were you I'd be looking for genuine 3k IPS panel. Not only it will offer you bigger res but also much better gamut.
Edit: BTW you need 40 pin eDP LCD panels.
W530
thinkreal
#3 Post by thinkreal » Fri Mar 06, 2020 7:32 pm
So i have a little more information. This should be 30pin since 40pin supports 3k.
I found an IPS panel in https://www.laptopscreen.com/193591/ and that looks like it may work as a replacement for my current FHD TN panel screen - anyone has replace this before?
moofish2842
#4 Post by moofish2842 » Sat Mar 07, 2020 11:39 pm
I have a W541 with the fhd ips screen upgrade. I purchased it already done from u/estebanmargooski over on r/thinkpadsforsale. I have seen threads about it before, possibly search for them on r/thinkpad?
Sent from my Moto Z3 Play using Tapatalk
W541 - i7-4940mx, 8gb RAM, Quadro k2100m
T530 - i7-3632qm, 8gb RAM, NVS 5400M; motherboard upgrade from t520.
T430 - i5-3320m, 4gb
T430s - i7-3520m, 8gb
Helix 1st Gen - i5-3337u 4gb
Other experience with X230t and t540p
I am 15 years old
Return to “ThinkPad W530/W540/W541/W550 Series”
Users browsing this forum: No registered users and 54 guests
