T480 Battery 1 Not Charging
T430-T495, T530-T590 Series
wiivile
#1 Post by wiivile » Wed Apr 08, 2020 9:31 am
After discharging to 5%, the Battery 1 on my T480 is not charging.
Battery 2 discharges and charges like normal.
I am using the 65W power adapter. I tried using a different 45W power adapter I had lying around, same problem.
Any ideas for the reason behind this behavior? I'm on Windows 10.
theterminator93
Re: T480 Battery 1 Not Charging
#2 Post by theterminator93 » Wed Apr 08, 2020 2:34 pm
Can you see any additional details in Lenovo Vantage? There are also settings for gauge reset, charge thresholds etc. that you might try adjusting to see if the battery will start to charge again. It may also give you a reason behind why it's not charging currently.
The recovery sets guy
wiivile
#3 Post by wiivile » Wed Apr 08, 2020 4:32 pm
Unfortunately I can't install Lenovo Vantage due to corporate restrictions. Not sure if there's another workaround to see potential battery issues.
theterminator93
#4 Post by theterminator93 » Wed Apr 08, 2020 8:48 pm
I'm not aware of anything that wouldn't require admin rights. You may be able to see something in BIOS but I can't say for certain...
Since you mentioned it's a corporate machine, have you tried reaching out to your corporate IT helpdesk?
wiivile
#5 Post by wiivile » Thu Apr 09, 2020 3:12 pm
Yes, they want to take a look at the physical battery but the office is closed. They say the battery may be defective or have been damaged due to the Thunderbolt issue?
JMAS
#6 Post by JMAS » Thu Jul 08, 2021 8:07 am
Today I experienced the same problem, the battery 1 would show a state of charge 5% and battery 2 100%. Battery 1 was not being charged.
I tryed executing the application Lenovo Vantage and looking for system updates. A couple of updates were found:
ThinkPad Hotkey Features Integration Package Setup - 10 [64] - 9.2.0.4
ThinkPad BIOS Update - 10 [64] - 1.37
I installed both updates and after reboot the battery 1 is being charged again.
Hope this helps!
marchoy
#7 Post by marchoy » Tue Jul 27, 2021 4:14 pm
Hope this helps!
This worked for me too. Thank you!
