[X270] Type 20HN - upgrade to touchscreen ?
i have an X270, Typ 20HN, i5-7200, i want change from fhd to fhd touchscreen. I only found X270 Typ 20K6 with Touchscreen. Not the Typ 20HN, i open the display cover and count the contacts, its 30pin.
In ebay i found Touchscreen for Typ 20HN but the sellers wrote it have 40pins.
Anyone here have an X270 Typ 20HN with touchscreen or can wrote me the fru numbers ?
in reddit i found this numbers:
01HY585 (lcd cable w/ touch)
01HY494 and 01HY494 Touchscreen display but maybe 40pins
Please help
greets, Peter
Please help
greets, Peter
Re: [X270] Type 20HN - upgrade to touchscreen ?
01HY494 12.5 FHD IPS AG touch, 300nit, AUO
01HY495 12.5 FHD IPS AG touch, 300nit, IVO
I have an X250 with touchscreen, very similar to the X270.
The X250-touch has everything different from non-touch: different cable, screen, lidcover, hinges, bezel, the works.
One can assume that the same applies to X270.
Find a complete touch-lid to simplify matters, or give up the idea of finding all those parts.
but this 2 screens have 40pin ...
Yes they are 40-pin, while non-touch is 30-pin.
My X250-touch has 30-pin, 400nit, LG LP125WF2-SPB2, FRU 00HN747, maybe that fits also?
and the cable connector on the display is in the middle ?
Can you make an pic of the front from your x250 ?
maybe you have an glass and complete other bezel than this here:
https://www.laptoparena.net/lenovo/note ... 06cus-6515
Many thx
greets, Peter
Many thx
greets, Peter
This X250 shows its touch/glass screen very well if you zoom in: https://www.ebay.ie/itm/254622054384
Screen connector is to the right (seen from the back).
its not possible for the x270.
however why would you even want it? the precision touchpad and trackpoint together are amazing and good enough.
x270 does not have capability for "on-cell" touchscreen for that type of LCD panel.
the x250 touchscreen is a whole different LCD assembly that has the touchscreen layer on the exterior of the screen.
CPC464
I've got an X240 with touchscreen and I found a cheap X270, but it has got a TN panel in it. I'd like to buy it and swap the whole screen lid from the X240 to the X270, in order to have a X270 with FHD IPS display, but I don?t know if it is possible, even if the X270 board would support a touchscreen at all.
Would this swap be possible, or is it a no-go?
Thank you!
Thank you!
X220 IPS, i7 16Gb RAM 250Gb SSD+2Tb HD
X61 T8100, 8Gb RAM, Middleton BIOS, 480 Gb SSD, sxga+
W520 i7 quad, FHD, 32Gb, 512 SSD+2Tb HD
W701 24Gb RAM, WUXGA, 240 Gb SSD+1Tb HD,
others
X61t, X200t, W500, T43p UXGA, R50p UXGA, T60p UXGA
600, X21, X24, X30, X41, A30p UXGA
According to the X240 and X270 schematics, they both use the same 30-pin LCD-connectors Ipex 20374_030E_31 with identical pinout.
So in theory you could swap.
Whether that works in practice?
No idea, because of touch/non-touch.
CPC464
Thank you! I'll give it a try, just for curiosity!
others
CPC464
Swap done!
I installed the X240 FHD screen in a X270, and verything works OK, except for the touchscreen, that doesn't seems to Work. What is strange is, that Windows 10 detects it and installs a generic driver for it. It can be seen in the device manager as a working device, but it doesn't work.
Maybe is there a more specific driver, or it is a no-go and for some strange reason the touchscreen is recognized, but not working?
The original X270 type I've used is 20HMS0GW1A
others
you able to make the x270 touch screen works? thanks
- 4 Replies
- 3437 Views
Last post by jruschme
Tue Dec 23, 2025 11:51 am
- 0 Replies
- 298 Views
Last post by chesed_of_ruina
Sun Apr 12, 2026 2:16 pm
- 5 Replies
- 10677 Views
Last post by Python.p
Mon Oct 27, 2025 3:57 am
T440p CPU upgrade + dGPU question
by brendenbogi » Thu Nov 06, 2025 11:19 am » in ThinkPad T430-T495 / T530-T590 Series - 7 Replies
- 11754 Views
Sun Nov 09, 2025 12:07 am
