(031926U - Edge 15) Can't get WiFI To Install Right On Windows 7 x64
I installed windows 7 pro. I had to go to the EOL portal at Lenovo to get the graphics drivers and then I grabbed every driver under the wireless LAN category. So far, NONE of the drivers for the wireless LAN are working and I'm only left with the ability to connect by ethernet. I even tried downloading System Update to see if it would find the driver I need, but it only showed an update for the ethernet LAN.
Re: (031926U - Edge 15) Can't get WiFI To Install Right On Windows 7 x64
Did you install any chipset-drivers yet?
Also, go to the wifi-card mfg-site (Intel or RTL) to get their drivers.
If that machine has a wifi-whitelist, the best card would be Intel 6300N.
If not, get an Intel AC-7260 such as this: https://www.ebay.ie/itm/303239756571
I installed the chipset drivers through System update, but that didn't make a difference. I eventually recalled the name of the device that showed when I used Linux and googled the drivers under that name. I ended up landing on a Lenovo page for Wifi drivers for a different model Edge series and just downloaded and installed what was there.RealBlackStuff wrote: ↑Tue Dec 08, 2020 6:22 amDid you install any chipset-drivers yet?
Dunno why the drivers listed on Lenovo's page for my model didn't work, but the one I downloaded worked like a treat.
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10648 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
Can't enter wifi-Password in a hotel or anywhere else?
by RealBlackStuff » Mon Dec 22, 2025 2:31 am » in Windows 10/11/etc. - 2 Replies
- 4209 Views
Last post by Scorpion8
Mon Dec 22, 2025 6:38 pm
Get a dual heatpipe mod for your t480, trust me
by swordslasher » Tue Dec 16, 2025 8:43 am » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 10660 Views
Wed Jan 28, 2026 3:06 am
Is it possible to get UDMA on a 760LD with Win98 SE ?
by aka_mgr » Sat Mar 14, 2026 4:56 pm » in ThinkPad Legacy Hardware - 1 Replies
- 1195 Views
Sun Mar 15, 2026 2:56 am
