X100e Project for Christmas
X100e/X120e/X130e/X140e Series
TitoLabieno
#1 Post by TitoLabieno » Thu Dec 10, 2020 7:19 am
Hello! The Christmas season is around the corner and I'll be having some spare time. I'm thinking about taking care of my old X100e which has been on reserve for a few years. It is a fairly slow machine and it can't even run Windows 7/10 smoothly due to the mediocre CPU it has, but it will be funny to tinker a bit. It is also a "different" project, as I have seen very few machines like those in use. I know it is a cheap consumer grade Thinkpad, but it is special for me.
This is what I'm planning to do:
1. Opening and cleaning it inside. That includes the heatsink fan, reapplying fresh thermal paste and removing the dust it might have.
2. Upgrading the WLAN card. I have a spare Centrino Advanced-N 6205. That card is tricky, it works fine but I replaced it from a T430 because I needed Wi-Fi AC and bluetooth. I have tried it on other old laptops (Asus, Dell, MSI...) but it refuses to work under Windows (haven't tested it on Linux). It is properly recognized but device manager said "This device cannot be started" with a warning sign. It has lenovo markings and FRU numbers written in it, does it have a custom Lenovo firmware which prevents it being used on other laptops? Also, does the X100e BIOS have a WLAN card whitelist?
3. Dropping a new system there. It has a spinning Hitachi HDD, which is not that fast but the bottleneck was the CPU anyways. I'll probably install a light *nix there (any recommendation here?) as the only Windows version which worked fine was XP and it is not recommended due to security concerns.
4. Installing a new CMOS battery. The one it has is already dead, and being a low-grade device, it is not as serviceable as any other X-T series. You have to literally remove the motherboard (full disassembly) to reach the CMOS battery.
5. Trying to improve the cooling. That Athlon CPU is hot as the sun running Windows. I wonder if kryonaut paste+*nix will make it better... Anyways, if you know any "hack" or way to reduce the heat it generates (I have very limited experience with old laptop AMD CPUs), let me know.
6. RAM: Already maxed out. Years ago I was able to get some 2GB modules, so with 4GB (DDR2) it is more than enough for anything with that CPU.
I don't intend to use it as a daily driver as it is too slow, but it will be a funny little project. It might be a good music/video player on the living room. The battery still last an hour or more even with that power hungry CPU, and the rest machine is in pristine condition (I took care of it).
Do you know any mod I could perform on it appart from what I have mentioned? Last time I took it appart was many years ago.
T480 (Intel Core i5-8350U 32GB DDR4)
T430 (Intel Core i7-3632QM @ 2200MHz, 16GB DDR3L)
X100e (AMD Athlon MV40 @ 1600MHz, 4GB DDR2)
R50e (Intel Pentium M 715 @ 1500MHz, 512MB DDR)
T23 (Intel Pentium III M 1133 @ 1133MHz, 512MB DDR)
Re: X100e Project for Christmas
#2 Post by axur-delmeria » Thu Dec 10, 2020 7:37 am
The X100e has always been hot. You can try Linux and undervolt the processor using phc-k8. You can grab the source code at https://github.com/cablespaghetti/phc-k8 because the linux-phc.org site is dead.
TBH I doubt even Kryonaut can help. You probably need liquid metal to get the temps down by a significant margin.
I recommend upgrading from HDD to SSD.
TitoLabieno
#3 Post by TitoLabieno » Thu Dec 10, 2020 8:47 am
Yes, a new SSD is always a nice addition, something like a 120GB Crucial BX500 for 20€ should be good enough. However it was intended as a "low-cost" project, the only component I needed to buy was the CMOS battery as I have everything else. I'll consider it. Thank you very much, I'll definitely try to undervolt that Athlon!
phinktad
#4 Post by phinktad » Thu Jul 20, 2023 9:09 am
Hello, I just got an X100E also. Trying to fix it up. Just got a new 6 cell battery and sharing a charger with my T400. The issue I'm having now is the CMOS battery. I saw on the motherboard, the socket has two pins, the first is marked with a dot, and the second has a number 2 printed on it. What of connector is this because most of what I see online is using a white molex connector. And this dot is supposed to be the positive or negative terminal? Can someone help advise, because not many sellers are selling this thing type connector,and I need to be sure which is which.
Thank you.
#5 Post by RealBlackStuff » Thu Jul 20, 2023 12:51 pm
Open up the plastic cover of that CMOS.
Get another regular 3V CMOS like CR2032 or the thinner CR2016 from most supermarkets or pharmacies.
The red cable is plus, the black is minus.
Carefully tear the old contacts off, straighten them, then tape them tightly on the correct sides of the new CMOS.
Make sure to cover the complete plus-side with tape.
Return to “ThinkPad X100e/X120e/X130e/X140e Series”
