T520 & External HDMI Display via DisplayPort++
DiagonalArg
I'm running Win10 on my T520, and trying to use an external HDMI monitor though the DisplayPort++ along with a *passive* adapter. The display is a Dasung PaperlikeHD (2019), and all I'm getting is a vague image and snow. I'm wondering if there are any quirks of the T520's DisplayPort, which I believe is 1.1a. The passive adapter i'm using is:
https://www.amazon.com/iVanky-DisplayPo ... B01N6M2VN4
Thanks for any insight!
Re: T520 & External HDMI Display via DisplayPort++
The adapter you linked is a miniDP to HDMI. The T520 has a full size Displayport. How does it fit?
In most cases, it's an issue with the adapter and/or cable.
Also note that a passive Displayport to HDMI dongle maxes out at around 1920x1200@60Hz, you cannot force a resolution higher than this.
Any higher requires an active adapter.
DiagonalArg
I just used the adapter on the end of this:axur-delmeria wrote: ↑Tue Dec 22, 2020 11:58 pmThe adapter you linked is a miniDP to HDMI. The T520 has a full size Displayport. How does it fit?
https://www.amazon.com/gp/product/B08MDTCZ3S/
That's right. It's the reason that though I wanted to use the active adapter to accommodate the higher resolution of that screen, I also ordered the passive one just to make sure. Turns out, I get exactly the same result whether I use the passive or active adapters. Here's what the output looks like:axur-delmeria wrote: ↑Tue Dec 22, 2020 11:58 pmIn most cases, it's an issue with the adapter and/or cable.
https://imagebin.ca/v/5lgr0cUvBaAd
I'm just trying to get this to work on Windows. I really want to be able to use it on Ubuntu, but so far the results there are worse.
That Ivanky link on Amazon says that HDMI to MiniDP does NOT work.
Mini DP ..X.. HDMI
Image <<<<< Image
Mini DP ..X.. HDMI
Image <<<<< Image
DiagonalArg
@RBS - what that's showing is that the signal goes from the laptop to the monitor, but not in reverse. All adapters are unidirectional.RealBlackStuff wrote: ↑Thu Dec 24, 2020 2:25 amThat Ivanky link on Amazon says that HDMI to MiniDP does NOT work.
Mini DP ..X.. HDMI
Image <<<<< Image
Sweater Fish Deluxe
Do you have access to a monitor with DisplayPort in? If so, you should test on that first to make sure it's not a more basic problem with the video output on your T520.
I'd also try the DP-to-HDMI adapters you bought on a more standard monitor with HDMI to determine whether the problem is with the tolerances of the eInk display you're trying to drive.
Honestly, the adapters themselves being the issue would be my last guess given the semi-working image you're getting. Usually DP-to-HDMI adapters either work or else produce no image at all in my experience.
DiagonalArg
I've done that in the past with one of these W/T520; W/T530's, though I'm not sure which. I know it worked with one of them, but the other machines don't have Windows and linux is presenting it's own problems (I just get streaks across the screen). Also, I'm not going to be home until the end of January, and that's where all my other equipment is loacted. I'm limited to Amazon for the moment.Sweater Fish Deluxe wrote: ↑Thu Dec 24, 2020 5:15 pmDo you have access to a monitor with DisplayPort in? If so, you should test on that first to make sure it's not a more basic problem with the video output on your T520.
I've used the dock before with more standard monitors using their HDMI in. With the docks' HDMI out, IIUC that comes to the same thing - it's passing through to DP++. I did use that with this T520.Sweater Fish Deluxe wrote: ↑Thu Dec 24, 2020 5:15 pmI'd also try the DP-to-HDMI adapters you bought on a more standard monitor with HDMI to determine whether the problem is with the tolerances of the eInk display you're trying to drive.
Alright, thanks. I do have an old Xoom pad with me, which has a micro-HDMI out. If I can get an adapter for that, I might be able to at least confirm the display works.Sweater Fish Deluxe wrote: ↑Thu Dec 24, 2020 5:15 pmHonestly, the adapters themselves being the issue would be my last guess given the semi-working image you're getting. Usually DP-to-HDMI adapters either work or else produce no image at all in my experience.
(Boy these display connector standards are a bear to get a handle on. I had to do a *lot* of reading.)
Hi, T520 is a tried and tested laptop, DP -> HDMI adapters are pretty dumb/simple, however the Dasung here is a relatively new complicated and not very well tested piece of equipment. My bet - though I don't have anything to base it on - is that it is the Dasung that is misbehaving.. That's a shame I have myself been thinking of paring a Dasung with a T520 under Ubuntu.. I am wondering though if this particular Dasung may have issues or if it is generally a tricky thing to feed them.DiagonalArg wrote: ↑Tue Dec 22, 2020 11:15 pmI'm running Win10 on my T520, and trying to use an external HDMI monitor though the DisplayPort++ along with a *passive* adapter. The display is a Dasung PaperlikeHD (2019), and all I'm getting is a vague image and snow
Have you been able to select resolution in Windows that you're feeding to Dasung? Which resolution/display refresh rate have you chosen? What resolutions is the Dasung supposed to support? Have you tried lowering resolution and/or display refresh rate from Windows? Is it any better? Are you at least matching Dasung screen ratio with your resolution? Has this Dasung been proven to work with anything at all? Can it be just broken?
Also are you able to invoke screen menus from the Dasung itself? I've never used one but I thought there is quite an elaborate set of menus on them and that you can probably operate these menus via buttons on the unit itself, is that right? Do the menus show up? Does toggling anything in those menus make things better? Which "modes" have you tried?
Also I understand there is some optional software offered by Dasung for Windows. Have you tried it? Can it communicate with the display? Can it toggle anything? Can you toggle screen cleaning via this software?
X220, 2 *T520
Perhaps a Linux live USB can help diagnose the issue... if the problem persists on Linux, then the likelihood of a hardware issue increases.
DiagonalArg
I just wanted to give the upshot of this ... I was unable to get the display working on Ubuntu or Windows. I just sold it to someone who is using it on their Mac, and it looked *really nice*. It was immediately plug-and-play. I was kind of jealous, but there's no way I'm leaving linux or my T/W52/30's. Perhaps at some point I'll get an ePaper pad or even a phone.
@atagunov - the software is for the previous version of the display. This one claims to need none.
T41 BIOS Update Via USB
by OldeThinkPadEnthusiast » Fri Nov 28, 2025 2:00 pm » in ThinkPad T40/T41/T42/T43 Series - 2 Replies
- 7760 Views
Last post by OldeThinkPadEnthusiast
Wed Dec 10, 2025 4:09 pm
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10648 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
FHD IPS for T520
by TP_ » Mon Feb 16, 2026 1:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 6547 Views
Last post by dcfbf
Mon Feb 16, 2026 3:41 pm
FS: T520 FHD $70 continental usa
by TPFanatic » Wed Mar 04, 2026 5:56 pm » in Marketplace - Forum Members only - 0 Replies
- 4425 Views
Last post by TPFanatic
