Hello everyone. I have a T510 and I'm planning on upgrading it with a i7-920xm and a dedicated GPU, and the only thinkpad able to support that is the W510, so I thought of buying a W510 motherboard for it. Would it fit properly, would it need simple modifications or is it just impossible to do?
Also, I've seen some posts of doing the opposite thing, putting a T510 motherboard on a W510, that's why I think it could be done.
W510 motherboard on T510
segfaultdev
Re: W510 motherboard on T510
T510/W510 use the same HMM (manual), so you should be good.
Outside the 15.6-inch class, the W701 and the W701ds are capable of supporting the Core i7-920XM/940XM as well.
Yes and no.segfaultdev wrote: ↑Wed Jan 13, 2021 6:07 pmWould it fit properly, would it need simple modifications or is it just impossible to do?
You need to source some parts from the W510 while you're at that, such as the heatsink and its specific AC adapter (135 W). Be wary of some W510 motherboards with only 2 SO-DIMM slots too, as those are not capable of supporting a 1st generation quad-core Core i7 processor. As long as the motherboard has 4 SO-DIMM slots, this is nothing to worry about, but just be careful.
If going through the trouble of a board swap you may find a better upgrade in a W530 for the faster CPUs and GPUs. Note W530 with a 7 row requires hardware and firmware mods for optimal function.
As mentioned by others you would need the W-series power brick and heatsink.
sent from my iPhone
FS: Lenovo ThinkPad T510 Core i5
by PiZzA EnGiNeEr » Tue Dec 16, 2025 12:50 pm » in Marketplace - Forum Members only - 1 Replies
- 4232 Views
Last post by PiZzA EnGiNeEr
Wed Dec 31, 2025 5:29 pm
Just bought a T510 with i5-540M
by ShellieACarlson » Sun Feb 08, 2026 12:29 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 2499 Views
Last post by lurespend
Mon Apr 20, 2026 11:34 pm
W510 maximum memory
by tpribors » Tue Feb 24, 2026 12:51 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 2 Replies
- 2608 Views
Last post by tpribors
Tue Feb 24, 2026 1:15 pm
W510 Windows upgrades fail
by tpribors » Sat Feb 28, 2026 9:55 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 6 Replies
- 4863 Views
Thu Mar 05, 2026 12:51 pm
