X3100 / 965 express Intel graphics webGL-enabled driver
According to the WebGL help page, the X3100/i965 intel graphics that's used in some older TP (X61 in my case, and some other of similar gen) COULD be compatible, but requires the Intel driver version 8.15.10.1930, while Lenovo offers only .1867 for the X61S. I've found the .1930 driver here but it says the computer is not listed as authorized for this version.
Anyone has tried / had more luck? Or knows a trick there?
Workhorse: vanilla X61s. "Gaming": 14s-IWL. Drawer: X31, X201s (sold, couldn't get used to it...). Office: T560. First crush: X20. Fond memories: SXGA+ 770
kfzhu1229
Re: X3100 / 965 express Intel graphics webGL-enabled driver
From my brief experience with the X3100 graphics in Windows 10, the experience was horrible. Lots of tiny graphical glitches here and there and crappy image quality on higher resolution panels (X61 should be fine). Install directly using the device manager?
Also on a side note I am curious about your 770 with dead power board as I have a 770ED with the exact same problem and it would be nice if I can find what's actually the culprit.
I imagine it's the 3.3V power supply chip that's dead as 3.3V is not found while only 16V is.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Sorry that was a long time ago, I don't have it anymore!
kfzhu1229
Ah okay well I found it rather baffling that the power board gave up and I was not able to get it fixed thanks to pretty much all laptops from that era having no schematics.
For now I put my suspicion on a potentially dead max1631ea1 chip as it receives 16V but outputs no 3.3V or 5V, and that I remembered plugging in a USB that sends power through the USB port made it turn on somewhat.
Anyway have you tried forcing Windows to install the drivers?
UXGA:
UXGA:
I doubt you'll be able to get webGL on the GMA X3100. Why? webGL 1.0 is based on OpenGL ES 2.0, which in turn is based on OpenGL 2.0. The Windows driver for the GMA X3100 only has OpenGL 1.4 support.
But it's possible that the .1931 driver somehow has better support? OK, I doubt it, but I got the info from the WebGL mozilla.org page which list driver versions which are supposed to work (here), and it seems like a rather good source.axur-delmeria wrote: ↑Wed Feb 03, 2021 6:48 amI doubt you'll be able to get webGL on the GMA X3100. Why? webGL 1.0 is based on OpenGL ES 2.0, which in turn is based on OpenGL 2.0. The Windows driver for the GMA X3100 only has OpenGL 1.4 support.
Anyway.. if the driver is not installable (I tried unzipping and installing from the device manager, too), the point is moot! Also if it worked it would likely be very slow.
kfzhu1229
Actually slow isn't even gonna be the biggest problem. The biggest problem with Intel iGPU's is that sometimes they have poor compatibility and causes graphical glitches! that's especially apparent with X3100 in Windows 10 where practically no UWP apps will work properly. The NVidia chip simply has far better driver support, and the latest drivers for NVS 140M are a whole 6 years newer! But yeah it's a X61 so you don't have that option.
UXGA:
UXGA:
iamdmc
Hello fellow Canadians and X61 loverskfzhu1229 wrote: ↑Wed Feb 03, 2021 4:06 pmActually slow isn't even gonna be the biggest problem. The biggest problem with Intel iGPU's is that sometimes they have poor compatibility and causes graphical glitches! that's especially apparent with X3100 in Windows 10 where practically no UWP apps will work properly. The NVidia chip simply has far better driver support, and the latest drivers for NVS 140M are a whole 6 years newer! But yeah it's a X61 so you don't have that option.
Did you ever get the X61 X3100 to play nice with Windows 10? I'm trying to drive an external 1080P LCD (connected to an eDP board, and active VGA out from X61 to HDMI into the eDP board) at 1920x1080 but I get black bars on the sides -likely due to hsync or vsync issues but I can't figure out how to fix
Strangely, it outputs correctly when viewing the Windows 10 desktop through a remote desktop (Anydesk) so it's definitely a VGA-related issue, but a software one rather than hardware because... It works perfectly on Ubuntu 20.04 - no config needed.
I've tried every 965/945 express and X3100 driver that I could find and nothing has worked in Windows 10. Any ideas?
ThinkPad X1C gen10 (2023)
i5-1235U | 16GB RAM | 2TB Samsung 990 Pro | QHD OLED
The X61 is dead... long live the X61
Past * current IBM (&lenovo) ThinkPads: X1C12, X1C10 P14s gen2, T480s, T450s, X250, X230, X220, X300, T410, X61s, T60p, T41, X31, T23, A21m
It's the other way around. It's software (such as games) what ships broken and creates the artifacts. nVidia just got good at embedding workarounds to make broken software to run "properly".kfzhu1229 wrote: ↑Wed Feb 03, 2021 4:06 pmThe biggest problem with Intel iGPU's is that sometimes they have poor compatibility and causes graphical glitches! that's especially apparent with X3100 in Windows 10 where practically no UWP apps will work properly. The NVidia chip simply has far better driver support.
Users usually don't really know what's going on and simply assume that, if it "looks good" then "works fine". But it's not the case. And a big part of the reason why alternate OSes such as Linux find it hard to support features normally available in Windows: sometimes the hardware itself is faulty, and it doesn't work as it is supposed to, but this is hidden from the user via a series of workarounds (starting by the upgradeable CPU microcode).
kfzhu1229
You should just get an older 1080p or WUXGA monitor that supports VGA instead of fiddling with the chain of converters that you have.iamdmc wrote: ↑Tue Sep 14, 2021 6:31 amHello fellow Canadians and X61 lovers
Does the 965GM support DVI output? I know the older 915 series don't. If you can get DVI working, just use DVI to HDMI through the dock and that would be a world better.
Besides, the 965GM struggles really badly with WUXGA resolution anyway
As far as running Windows 10 is concerned, the fact that the 140M has Windows 10 drivers and also has full DX10 support makes it much more usable than the 965, which is still stuck with Windows 7 drivers and doesn't have DX10 support.
If you have ever tried the earlier generation of NVidia GPU's, like the NVS 130M and the Quadro FX 350M, 3500M, it is just as sketchy in Windows 10 as the 965GM is. It's strange that those don't even have proper Windows 7 drivers while the NVS 140M has Windows 10 drivers.
UXGA:
UXGA:
iamdmc
thanks for the replykfzhu1229 wrote: ↑Tue Sep 14, 2021 1:07 pmYou should just get an older 1080p or WUXGA monitor that supports VGA instead of fiddling with the chain of converters that you have.iamdmc wrote: ↑Tue Sep 14, 2021 6:31 amHello fellow Canadians and X61 lovers
Besides, the 965GM struggles really badly with WUXGA resolution anywayAs far as running Windows 10 is concerned, the fact that the 140M has Windows 10 drivers and also has full DX10 support makes it much more usable than the 965, which is still stuck with Windows 7 drivers and doesn't have DX10 support.
I don't think the 965 has any problems with 1080p - just with poor drivers (the most recent being a 2009 file) in Windows 10/8/7/Vista
Since it works in Ubuntu 20.04, it should work in Windows 10 with the right drivers (or settings through the intel graphics utility which allow editing of hsynch, vsynch, resolution, refresh, etc. - I just haven't cracked it)
the real reason to do this is because I'm trying to use a modern IPS/LED 1080p LCD panel with an eDP to HDMI driver board, and wire up the VGA port to connect with the VGA-to-HDMI active adapter.
@kfzhu1229 I don't think you should be going around basically recommending the NVS140. That's NVIDIA 8000-series, they are notorious for dying. While you can get a way higher OGL level, I think even OGL 3.X, I don't think it's worth the risk, especially since used devices with that chip could have already went through a death without the buyer's knowledge, which could reduce the GPU's life by quite a lot, on top of the additional potentially short life. Not to mention the worse Linux support in case the device ever has to migrate there, which with Microshaft's bad practices is not unlikely.
And also, if I remember correctly, the newest Intel driver for the X3100 actually does support OpenGL 2.0, if what I did here is anything to go by: https://user-images.githubusercontent.c ... 5fc115.png. That's using the newest driver for this GPU from Intel's website. But your application has to be the same architecture as your Windows system, this is 64-bit. On the left is what happens if you use a 32-bit OpenGL application on 64-bit Windows with this driver.
Note that Windows 10 is a horrible choice for anything this hardware, though. You will likely need to explore this at the very least to even get a chance at any OpenGL on W10: https://github.com/pal1000/save-legacy-intel-graphics
As other people have already said, you will get better OpenGL either way on Linux.
X40, T60 (ATI X1300), X61 (melting), T61 (Nvidia NVS140
), X201 (main), T420, T430 (beheaded) - Windows 7 homebrewer and fanatic, Debian enjoyer.
You obviously never heard of these 'new old stock' T61 motherboards with a perfect NVS140M: https://theboardroom.info/t61mobo.html
I have not! That's neat, nevermind if you're buying one of those I suppose.
thinkpadrobert
Have you tried this:tecmes wrote: ↑Mon Feb 01, 2021 6:32 pmAccording to the WebGL help page, the X3100/i965 intel graphics that's used in some older TP (X61 in my case, and some other of similar gen) COULD be compatible, but requires the Intel driver version 8.15.10.1930, while Lenovo offers only .1867 for the X61S. I've found the .1930 driver here but it says the computer is not listed as authorized for this version.
https://danielkawakami.blogspot.com/201 ... -pack.html
Unfortunately I'm on win7, and it seems that driver is precisely meant for win8 - and "restores" a support, which I'm not sure what it means re: webGL here.thinkpadrobert wrote: ↑Thu Apr 21, 2022 8:06 pmHave you tried this:
- 10 Replies
- 10114 Views
Sun Dec 21, 2025 4:38 pm
Better graphics on recent linux for x61t
by thinkpadrobert » Sun Oct 26, 2025 1:40 am » in Thinkpad X60/X61 Series incl. Tablets - 1 Replies
- 13215 Views
Sun Oct 26, 2025 9:40 am
Selectadock III Graphics Card Compatibility
by NineVolcanic » Sat Feb 21, 2026 12:22 pm » in ThinkPad Legacy Hardware - 1 Replies
- 1719 Views
Last post by panips
Sat Feb 21, 2026 8:19 pm
- 8 Replies
- 15531 Views
Last post by Loci
Fri Oct 31, 2025 3:02 pm
