internal speakers very low volume...forced to plug in earphones
Suggestions on replacing the internal sound speakers with noisy internal sound speakers ..please..
I just got my T400 opened up yesterday to know why the internal speakers were so timid.There was a lot of
dust which I cleaned to no avail. SO I need this help ...Can I tap some other internal speaker inside the laptop.
may be a tiny sound bar.!
p9500 1440 X 900 250GB SSD 8 GB
Re: internal speakers very low volume.solved
widows 10 T400 p9500
i installed the free windows version of DXF Audio enhancer.I downloadd it from the net.
I can here just loud enough the sounds from the internal speakers.
The file is FXSOUND_setup.exe . I installed the free version.
thanks to the people there.
Re: internal speakers very low volume...forced to plug in earphones
Some folks have success soldering better speakers from modern smartphones to replace the original puny ThinkPad speakers. I'm considering it myself for Z61t, which is also terrible.
sent from my iPhone
Were it IPad speakers that are normally advised? Something from old IPads. Though what OP complained about does seem more like a driver issue which would probably show up even with IPad speakers
X220, 2 *T520
The OP also thinks it as a driver issue but does NOT know alternatives. Happy to know that mobiles are good even after they become obsolete (within 3 /4 months). ..The sound..
those speakers are very pocket friendly for trials...
Is this battry BAD - T580 internal battery
by Scoobis » Thu Jan 22, 2026 10:33 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 3304 Views
Last post by Scoobis
Thu Jan 22, 2026 12:57 pm
