The charger cable for my X220 has to turn 180 degrees from where it plugs into the computer. How can I protect this charger cable from fraying like my last one did?
I think the best way would be to use a right angle adapter. I found posts viewtopic.php?t=116525 and viewtopic.php?f=18&t=91992 for right angle adapters, but I did not fully understand the discussion and if these right angle adapters can be used in all cases. Is it correct that the one in viewtopic.php?f=18&t=91992 should not be used for my charging cable because this adapter is not triaxial? Is there anything I need to consider before using the one in viewtopic.php?t=116525?
I think Sugru moldable glue could help a little, but I do not know how much. Are there other options that I could use to prevent a sharp bending radius for my cable?
Finding Ways to Protect Thinkpad Charger Cable from Bending Sharply - Right Angle Adapter, Sugru, etc.
WellLookieHere
Re: Finding Ways to Protect Thinkpad Charger Cable from Bending Sharply - Right Angle Adapter, Sugru, etc.
The adapter from viewtopic.php?t=116525 is the correct one.
Still available e.g. here: https://www.ebay.ie/itm/263632968445 (USA)
or a variant here: https://www.ebay.ie/itm/222658359962 (UK)
The other link goes to a 16V-20V adapter, NOT to be used!
(Or use an extension cord to achieve the same result).
Turn your desk/bed 180 degrees around, so that the power comes straight into your X220.Are there other options that I could use to prevent a sharp bending radius for my cable?
WellLookieHere
Thank you for confirming that first adapter is good to go!
Haha, I like to stand at the bar countertop while using my computer, so I can't flip it around, and if I stood on the other side I'd be reaching over the sink
AC adapter/charger for X201 (3113-X06)
by Brainer » Tue Nov 11, 2025 2:32 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 28 Replies
- 25418 Views
Last post by Brainer
Thu Dec 11, 2025 7:15 pm
Does anyone have a replacement ThinkPad 600 audio/mic cable!
by EpicOtterLover » Sat Jan 24, 2026 4:31 pm » in ThinkPad Legacy Hardware - 0 Replies
- 4832 Views
Last post by EpicOtterLover
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10651 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
Trying to find 14" LCD cable for T60
by Glaurung-quena » Sun Dec 07, 2025 8:32 am » in ThinkPad T60/T61 Series - 2 Replies
- 5386 Views
Last post by Glaurung-quena
Tue Dec 09, 2025 7:38 am
