W/T530 CPU Mod - HSF 04W3626 / 04W3623 sufficient?
DiagonalArg
Edited because I was getting @RBS confused!
I'm looking at upgrades to my W & T530's. The HSF's listed on the Lenovo website have no indication of their power capacity. I'm wondering if anyone knows which HSF's are sufficient for the upgrade?
W530 i7-3940XM upgrade:
Present HSF 04W3626
The other option is 04W3627
T530 i7-3840QM upgrade:
Present HSF 04W3623
The other options are 04W3622 and 04W3624
That 04W3622 is available but quite expensive. The other two I have not been able to find anywhere.
I'm hoping the HSF's that I have are sufficient, but I have my doubts. According to this T430 Modding Guide, the HSF's with the Delta fan are insufficient. Apparently those fans are quieter but don't do as good a job cooling. It just so happens that my present HSF's have that fan. So maybe my 04W3626/3 were the HSF's made for lower power?
Any insight would be appreciated.
Present HSF 04W3626
Present HSF 04W3623
Re: W/T530 CPU Mod - Delta Fan sufficient?
Here's an AVC fan from a T440p, look at it, it might fit in the T/W530 heatsink: https://www.ebay.ie/itm/363362618814
DiagonalArg
Sorry RBC. I was using "Delta" to refer to the HSF assembly. Those FRU's are all for HSF's. So I'm really asking which of the HSF's are necessary/sufficient for the upgrade.RealBlackStuff wrote: ↑Fri Apr 23, 2021 3:57 amHere's an AVC fan from a T440p, look at it, it might fit in the T/W530 heatsink: https://www.ebay.ie/itm/363362618814
(I've edited the OP for clarity.)
You don't understand... HSF a.k.a. Heat Sink Fan.
The heat sink itself is the chassis for a fan (such as I linked).
The same fan can often fit in various heat sinks with some modifications.
DiagonalArg
The Lenovo website lists those FRU's, which are Heatsink Fan (HSF) assemblies, with names: "Delta," "AVC," "Furukawa." That's why I used those names in referring to the assembly as a whole. I'm sorry if that got confusing. Hopefully my edits have clarified the OP.RealBlackStuff wrote: ↑Fri Apr 23, 2021 10:23 amYou don't understand... HSF a.k.a. Heat Sink Fan.
And theoretically/probably each group (iGPU or dGPU) could have the same chassis, but with a fan from a different manufacturer (such as Delta, AVC, Furukawa, Toshiba).
That's why you should look for a specific fan (to swap in) if your chassis is OK!
DiagonalArg
Ok, I'm really sorry that I produced confusion by bringing up these different fans at all.RealBlackStuff wrote: ↑Sat Apr 24, 2021 1:40 amAnd theoretically/probably each group (iGPU or dGPU) could have the same chassis, but with a fan from a different manufacturer (such as Delta, AVC, Furukawa, Toshiba).
To put it simply, I'm wondering which HSF's are going to be ok for the upgrades. Right now I have 04W3626 (W530) and 04W3623 (T530).
Alternatives are 04W3627 (W530) and 04W3622 / 04W3624 (T530). There is no information on the Lenovo site about one vs. another being higher power.
Footnote: Why did I bring up the fan at all? Because (1) the Lenovo site associates each of those FRU's - which are HSF's! - with a specific fan manufacturer and (2) because the T430 guide linked in the OP, expresses concern about one particular manufacturer. But what I want to know is which of those HFS's will work for the upgrade.
PS. After we get this straightened out, we'll have a Guinness together.
ChristopherWong
Re: W/T530 CPU Mod - HSF 04W3626 / 04W3623 sufficient?
I'm finally getting around to setting up a W530 with i7-3940XM that I purchased in 2018. It came with a faulty (loud, rattling) fan so I ordered a replacement part shortly thereafter. The part I purchased was a 04W3626 (Delta); I'm not sure if it was a conscious decision to pick it over the 04W3627 (AVC), but I don't think the difference in cooling performance between the two FRUs was on my radar at the time.
A few days ago I installed the new Delta cooler with Noctua NT-H2. After flashing 1vyrain, I set about testing overclocking with ThrottleStop but found that even with stock multipliers, Prime95 was causing the CPU to generate an amount of heat that I wasn't comfortable with, going up to 98 degrees or so in about five minutes. I'm usually pretty content to not tweak my computers so I'm not an expert with regards to overclocking, but given that the junction temperature for the i7-3940XM is 105 degrees, I don't think I can recommend overclocking it with the Delta installed.
It's a bit disappointing because I was hoping to be able to overclock at least a bit - but if you end up buying an AVC, I would be interested in knowing if you have more success. I'm actually typing this on a different W530, with i7-3840QM, and I'm tempted to open it up to see which cooler it has.
Edit: Just popped off the keyboard and palm rest on my other (actually first) W530 and it does indeed have an AVC cooler. I'll make the switch hopefully tomorrow and then report back with results.
ChristopherWong
I made the swap today and it seems to have worked out. This is just preliminary testing, but under the same conditions, the maximum core temperature under Prime95 is 90 degrees after five minutes (and 93 degrees after 20 minutes). It's still not a ton of thermal headroom for overclocking, but I'm happy with the improvement presented by the AVC relative to the Delta.
DiagonalArg
@ChristopherWong - That was just the insight I was looking for, thank you so much!
Now if anyone has any idea about which HSF assembly might work for upgrading the T530, I'd be pleased to hear.
i would be somewhat cautious of trying to push this cpu too far on this machine. I also have the 3940xm installed in my machine (with 3 SSDs - ordinary drive bay, dvd-replacement + wwan slot) and i saw some.. well "higher" temperatures as well when i installed the xm-cpu. I did what i easily 'could' do at the time, i bought the Kryonaut paste (and let me tell you that it was not very easy to find as it was sold out everywhere) and re-pasted the lot by the book. After this, i saw a substantial reduction in temperature from what it used to be. I don't push it very hard for now (probably will not do it at all going forward) but the most i see is ~84 celcius which i guess is within the acceptible boundaries.
W530 3940xm/32gb/520/240/240gb ssd, FHD
T410 w. I7-640m, 8GB, 240+128gb ssd hd, 1440x900
X61 w. T7500, 8GB, 240gb ssd, 1400x1050
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
760E
380ed
365xd
360cs
701cs
T21
T590 (work machine)
FS: ThinkPad T530
by PiZzA EnGiNeEr » Tue Nov 04, 2025 11:31 pm » in Marketplace - Forum Members only - 1 Replies
- 5914 Views
Last post by PiZzA EnGiNeEr
Wed Dec 31, 2025 5:29 pm
T530 Screen Upgrade to FHD Panel - Which Panel?
by Silverlake » Wed Dec 17, 2025 3:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 8819 Views
Last post by Silverlake
T530 screen flicker
by buzzliteyear » Fri Apr 10, 2026 2:32 am » in ThinkPad T430-T495 / T530-T590 Series - 5 Replies
- 1110 Views
Fri Apr 10, 2026 6:03 am
X32 SXGA+ Bios Mod
by Plunkyy » Wed Dec 03, 2025 3:01 pm » in ThinkPad X20/X30/X40 Series incl. Tablets - 0 Replies
- 4675 Views
Last post by Plunkyy
