Feeding 90W AC adapter with two prong plug?
Hello everyone,
I have a T480 with an adlx90nlt3a AC adapter, which has a three hole socket for the wall connection. The other side offers a USB-C power connection to the T480.
Currently, I am using a European Schuko plug (also named CEE 7/7 https://en.wikipedia.org/wiki/Schuko), but I wish to use my laptop in a place (rooftop) where only 2-prong plugs are possible (Europlug: https://en.wikipedia.org/wiki/Europlug )
Is it possible/safe to make an ad-hoc adapter from a Europlug socket to a Schuko socket?
I guess that line and neutral should be enough to feed the AC power adapter, but I would like to be sure before trying it.
Regards,
N.F.
Regards,
N.F.
Re: Feeding 90W AC adapter with two prong plug?
You can make one yourself, no problem, or get one of these: https://www.amazon.de/-/en/Travel-Plug- ... B088B3ZDHL
Should fit the 2 prongs from the Schuko.
RealBlackStuff wrote: ↑Wed Apr 28, 2021 12:34 amYou can make one yourself, no problem, or get one of these: https://www.amazon.de/-/en/Travel-Plug- ... B088B3ZDHL
Many thanks, I found such an adapter myself at a nearby shop. I suppose that's safe to operate the AC adapter this way, right?
N.F.
Yes.
It's not safe, because then you don't get the ground pin. But it's okay, I used to do the same thing. And I actually love it, instead of the bulky 3-prong plug. I envy the Italians in this regard. Reference: https://en.wikipedia.org/wiki/AC_power_ ... nd_sockets
Anyway, in case someone knows: How is the ThinkPad adapters with 3-pin cables (C5 & C6) different from those with 2-pin cables (C7 & C8)? Is the grounding system different? Can I safely use a C6-to-C8 converter on such adapters?
Thinkpad X32 - Thinkpad X60 - Thinkpad X61s - Thinkpad T420s
The 2-prong adapters, those without the grounding pin, are something that is called "double insulated". Supposedly it's electrically safe. I still prefer the 3-prong grounded versions where possible, but if your area has 2-prong sockets only, then you have no choice.
- 27492 Views
Sat Oct 25, 2025 8:30 am
AC adapter/charger for X201 (3113-X06)
by Brainer » Tue Nov 11, 2025 2:32 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 28 Replies
- 25559 Views
Last post by Brainer
Thu Dec 11, 2025 7:15 pm
Free: ThinkPad W520 20V 4.5A 170W AC Adapter
by PiZzA EnGiNeEr » Sun Nov 23, 2025 12:30 am » in Marketplace - Forum Members only - 1 Replies
- 7551 Views
Last post by dcfbf
Sat Dec 06, 2025 10:22 pm
Looking for X201 replacement keys/domes and 3mm stem to 4mm adapter.
by ThinkIsaac » Mon Dec 15, 2025 4:17 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 5076 Views
Last post by ThinkIsaac
