I have been looking for a way to adapt the HDD on my T23 so I can use SD/MMC cards with it (to be able to swap between configurations, and to make it easy to re-load a configuration to it using my more-current Linux desktop).
I know they have cards like this https://www.amazon.com/GODSHARK-Adapter ... B07QNB6QLC that take a full-size SD card (I should actually say *CARD*, as from what I can see there's only one manufacturer, but it's been rebadged under 500-600 different questionable resellers) but the card sits down inside the drive bay, and isn't removable without pulling the HDD (I'm thinking the machine is getting too old to keep putting stress on the HDD connector).
the SD card extenders I've seen have such long cables you'd be trying to fold them up with harsh bends just to fit them into the space, and the right-angle fold would be the worst. What I'd want is something a bit longer, and with the SD card port facing towards the outside of the drive bay (away from the pins). Anyone know of any such adapter? Amazon is worthless for the search, and some shady site like AliExpress doesn't have it.
Now, if my soldering was any good (Louis Rossmann I'm not) I might take the risk of buying one of these and seeing if the port could be un-soldered from the card, then make my own "harness" to put the port further out on an original ThinkPad HDD tray.
SD to 44pin IDE adapter with SD card accessible outside
jelabarre59
accidentally flipped a DOM module - now IDE is dead
by my03 » Sat Feb 21, 2026 8:37 pm » in ThinkPad Legacy Hardware - 3 Replies
- 2590 Views
Last post by kishy
Wed Feb 25, 2026 10:58 am
AC adapter/charger for X201 (3113-X06)
by Brainer » Tue Nov 11, 2025 2:32 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 28 Replies
- 25338 Views
Last post by Brainer
Thu Dec 11, 2025 7:15 pm
Free: ThinkPad W520 20V 4.5A 170W AC Adapter
by PiZzA EnGiNeEr » Sun Nov 23, 2025 12:30 am » in Marketplace - Forum Members only - 1 Replies
- 7516 Views
Last post by dcfbf
Sat Dec 06, 2025 10:22 pm
Looking for X201 replacement keys/domes and 3mm stem to 4mm adapter.
by ThinkIsaac » Mon Dec 15, 2025 4:17 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 5019 Views
Last post by ThinkIsaac
