T420s generic usb hub error keep popping up
hello
i have a t420s and recently it is giving me generic usb hub error some times.i tried to update drivers and it says it is up todate.
how do i post a picture in here?
Thank you
Thank you
Re: T420s generic usb hub error keep popping up
1. What OS are you using? Windows? MacOS? etc.
2. Upload the picture on an image hosting site (flickr or similar) then post the link here or use [img] to embed it in your comment. This site is strict about image sizes, so if it's larger than 1024x768, post it as a link, otherwise you'll receive a warning from the moderators.
I am using windows 7 pro in T420s 4173-2AUaxur-delmeria wrote: ↑Sat May 15, 2021 10:25 pm1. What OS are you using? Windows? MacOS? etc.
here is the link for picture i hope it work.
https://www.flickr.com/photos/193023761 ... res/oZyN2Y
It might be an actual hardware issue. Remember that T420s is a decade old by now, and any form of malfunction is to be expected.
Can you show more details on that unknown device? Right-click on it and select "Properties". Post screenshots of the contents of each tab.
Thinkpads have a number of integrated devices connected via USB. From memory WWAN card, Bluetooth adapter and Camera / Microphone at the very least. Any of them can be failing and reporting as a mysterious device. Try enabling / testing such features to see if they still work properly.
Also, if the machine has been used in a hot and wet environment, chances are that the connectors have been corroded. I recently purchased some old stock ultra slim ITX PC cases off eBay and the machine I built using one was throwing weird errors in Windows. The problem was corrosion in the front panel ports (audio and USB). I took the whole module off and the problem disappeared. Good thing it's a normal PCB, so I just need to go and find new USB ports (I'll get good quality this time... the old ones probably were bottom of the barrel stuff with no gold plating) and re-solder them. You can't do that to a laptop motherboard (well, you can, but it's far more difficult) so I'd try to rinse it with distilled water if you find some sulfate.
I was also getting a lot of trouble with early USB 3.0 external controller integrated into the motherboard (DH61AG). Renesas I think it was. It kept interfering with the normal USB 2.0 ports. I tried a different driver version (newer, I do remember reading they fixed some incompatibility) and the system went back to normal. The T420s uses an external USB 3.0 controller as well, since intel didn't integrate one into the chipset until Ivy Bridge.
Looking for T420s front plastic foot
by smashkenazi » Tue Jan 20, 2026 12:56 am » in Marketplace - Forum Members only - 1 Replies
- 2948 Views
Tue Jan 20, 2026 3:33 am
W520 doesn't boot after critical battery error...
by salzrat » Mon Mar 16, 2026 12:18 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 12 Replies
- 5127 Views
Fri Mar 20, 2026 1:32 pm
T420 BIOS update fails with "BIOS directory not found" error
by FastCabbage » Mon Apr 20, 2026 3:40 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 48 Views
Last post by FastCabbage
WTB: Lenovo USB-C Port Replicator 4XH1C12753
by stanleylieber » Fri Nov 21, 2025 10:07 pm » in Marketplace - Forum Members only - 0 Replies
- 5576 Views
Last post by stanleylieber
Users browsing this forum: No registered users and 75 guests
