Hi, I'm facing CPU throttling for a while now, I doubt it is temperature related and I've tried adjusting windows 10 settings to no avail.
The CPU is sitting mostly at 63/65°, around 1.3 & 1.6ghz, plugged to the power supply, even when the laptop is churning stuff, such as compiling code, etc.
It can normally run at 2.7ghz, or even higher for single CPU and short tasks. It sometimes seem to want to go to 0.2ghz and sit there once in a while even...
I've tried to fiddle a bit with ThrottleStop but it doesn't seem to enable anything.
Any idea how to diagnose and ultimately fix this?
Thanks.
CPU throttling issue?
Re: CPU throttling issue?
Sorry to hear about your issue - are you still experiencing CPU throttling?
I have had this same problem for many months, and wasted many days trying to fix it. FINALLY SOLVED TODAY!!
See full description of the problem, simple solution, and outcomes -- here: https://www.tenforums.com/tutorials/955 ... ost2354065
W520 and WiFi connection speed issue
by jdwis » Sat Nov 01, 2025 7:11 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 8 Replies
- 19746 Views
Last post by jdwis
Wed Nov 12, 2025 11:57 am
Display brightness issue with Win 10 on W520
by jdwis » Tue Nov 04, 2025 2:22 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 4 Replies
- 12918 Views
Last post by jdwis
Thu Nov 13, 2025 8:05 am
T440p CPU upgrade + dGPU question
by brendenbogi » Thu Nov 06, 2025 11:19 am » in ThinkPad T430-T495 / T530-T590 Series - 7 Replies
- 14327 Views
Sun Nov 09, 2025 12:07 am
