Hey folks,
I have a 'third batch' X210 from cnmod.cn. I'm struggling to get a Sierra Wireless AirPrime MC7710 working in the second mPCIe slot ("Minipcie 2" in Jackie's post here). I've tried simply installing the card, changing several seemingly relevant BIOS settings, and even taping pins #23, 25, 31, 33 per this article on Techship to disable PCIe -- all to no avail: nothing shows up in my USB device list in Linux.
Does anyone have any other ideas to try? My next route is to purchase a mPCIe to USB adapter, install the modem there, and tell it to ignore the W_DISABLE pin.
-N
WWAN on X210
TheForgottenKing
Re: WWAN on X210
Does that slot support USB? From what I know, the WWAN cards need USB support.
theforgottenki.ng
Surface Laptop 7: Snapdragon X Elite - 16GB LPDDR5x - 512GB NVMe - 15" 2496x1664
W701ds: i7-940XM - 32GB DDR3 - 256GB SSD + 1TB HDD - FX 2800M - 17" 1920x1200 + 10" 768x1280 - Wacom - Dock
PC XT: 5160 + 5151 + 5153 + F XT - Intel 8088 - 640 KB - 2GB CF
Re: WWAN on X210
I'm not totally clear on that either. I'm going on the assumption that it will support USB based on others' descriptions of that slot as supporting a 'WWAN CARD'.TheForgottenKing wrote: ↑Wed Jun 02, 2021 10:16 pmDoes that slot support USB? From what I know, the WWAN cards need USB support.
In any case, I purchased an mPCIe to USB Adapter Board from Pi Supply (which miraculously made it through Danish customs without incurring the questionably steep handling fee) and can enumerate the card now in a 5.12.9 Linux kernel. Not sure what an 'interface number' means in this context.
usb 1-6: new high-speed USB device number 6 using xhci_hcd
usb 1-6: config 1 has an invalid interface number: 8 but max is 4
usb 1-6: config 1 has an invalid interface number: 10 but max is 4
usb 1-6: config 1 has no interface number 1
usb 1-6: config 1 has no interface number 4
usb 1-6: New USB device found, idVendor=1199, idProduct=9071, bcdDevice= 0.06
usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-6: Product: Sierra Wireless MC7455 Qualcomm® Snapdragon™ X7 LTE-A
usb 1-6: Manufacturer: Sierra Wireless, Incorporated
usb 1-6: SerialNumber: LQ83...-
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 11635 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
M.2 SSD in P14s Gen 3 (Intel) (21AK)'s WWAN slot
by usescomputers » Sat Jan 24, 2026 5:57 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 0 Replies
- 4935 Views
Last post by usescomputers
Thinkpad p14s gen1 (Intel version) WWAN module
by EarthNature » Thu Feb 19, 2026 5:32 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 0 Replies
- 2558 Views
Last post by EarthNature
P14S Gen 6 AMD - WWAN Whitelist?
by H-Atkinson » Sat Feb 21, 2026 11:41 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 3 Replies
- 4160 Views
Tue Mar 10, 2026 5:27 am
