Is there any possible link at all? How to fix the problem?
No issues with the headphone sound.
Distorted sound (some freqs) from the speaker after mobo exchange (x230)
Re: Distorted sound (some freqs) from the speaker after mobo exchange (x230)
Sounds like speaker damage if the line output jack is sounding ok. Can you use the balance control to see if its just one or both speakers.
Where to begin......
390e FOR SALE : GONE
1 x T20 : SOLD
1 X T23 + 3 breaking for parts
1 X T23 with Samsung 840 SSD and XP Great combination !: SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
1 x T20 : SOLD
1 X T60
3 X T61
1 X T601 15"
1 X T520
2 X T530
Good idea, thanks. I will check and write back.
Meantime, can x200 speakers replace the x230 ones?
Speakers on X230 are honestly very low quality... if you look around there are some posts of hacks to fit in speakers from iPods or some Samsung Galaxy Tablet if I'm not mistaken... but the hacks needed to fit them are a bit nasty... Not worth the trouble in my opinion...
My recommendation is to use USB headphones (I use a Sennheiser PC8 for conference calls) or some external speakers connected via Bluetooth (if your X230 has Bluetooth).
High pitched speaker noise under Windows
by NBG » Mon Apr 13, 2026 9:34 am » in ThinkPad T60/T61 Series - 4 Replies
- 838 Views
Fri Apr 17, 2026 12:14 pm
T480 screen shuts off after a few seconds to a minute after starting to use it.
by FranklinHawkings » Wed Oct 22, 2025 5:26 pm » in ThinkPad T430-T495 / T530-T590 Series - 13 Replies
- 29845 Views
Sat Nov 01, 2025 12:09 am
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 6738 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
- 8 Replies
- 15469 Views
Last post by Loci
Fri Oct 31, 2025 3:02 pm
