[Thinkpad T420] The screw holding the shell with the CPU won't come off
hi im cool
#1 Post by hi im cool » Sun Jun 13, 2021 12:30 am
Hi, first time posting here so i'm still new to this, mb if my explanation sounds bad.
so recently, i got this T420 and i wanted to clean the CPU and fan/heatsink but this screw connecting the shell wouldn't come off.
i tried using my Phillips #00 and #0 on it and it wouldn't move despite being able to fit inside it.
is there something that can be used to open this screw?
Image Image Image
Re: [Thinkpad T420] The screw holding the shell with the CPU won't come off
#2 Post by RealBlackStuff » Sun Jun 13, 2021 2:35 am
Try a small, strong, flat screwdriver diagonally in the screwhole.
Or a pair of pliers.
Or tape everything around it up, then use a Dremel with a diamond disk to make a small groove in that screwhead.
Then use a flat screwdriver to first slightly tighten it (yes), then try and get it out.
hi im cool
#3 Post by hi im cool » Tue Jun 15, 2021 5:53 pm
Hi sorry for the late response, i tried the pliers and it worked in getting it out, thanks
