T60 with "dual boot": how to use Rescue&Recovery partition
BigCatAndy
#1 Post by BigCatAndy » Mon Jul 19, 2021 4:32 pm
Hello dear community,
I have following situation: I own T60, which came with valid Recovery Partition. I restored Windows XP of it, and then installed Linux on it (resizing Windows XP partition). GRUB added R&R-partition to the list, everything fine so far.
Now I want to use R&R again and restore Windows XP completely. Unfortunately, it fails. When I start R&R environment and say "Restore system", it reports - after some seconds - that several partitions where found, and asks if I want to restore partitions C:\, or the whole drive. When I choose "whole drive", it starts to restore, and breaks after several seconds with an error.
Here is my question: how can I restore WindowsXP from R&R in the case of dual boot?
I would appreciate any hint on it.
Regards,
Andrey
- in use -
(1) TP R61i Frankepad - 4 GB / C2D T9500 / 180 GB SSD / UXGA display
(2) Lenovo 3000 N200 - 2 GB / C2D T7300 / 160 GB
(3) TP T450s
- in museum -
IBM 600x, IBM TP T43p, Lenovo TP Z61t, Lenovo TP X60 Tablet
BigCatAndy
Re: T60 with "dual boot": how to use Rescue&Recovery partition
#2 Post by BigCatAndy » Tue Jul 20, 2021 6:16 am
update on my own post: I occasionally messed up my partitions, so now I have only "IBM_SERVICE" partition and Rescue & Recovery fails to restore from it. So, I would be happy to get any hint how to enable use of the recovery partition.
Andrey
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
#3 Post by dr_st » Tue Jul 20, 2021 7:36 am
So, wait, now you cannot boot any of your operating systems?
I recall that R&R always had problems with dual-boot. However, as long as the R&R partition is marked "active" and you can boot from it, it should be able to restore the entire drive (but will wipe and dual-boot OS you had in the process).
Not sure what to do at this point, but the general advice (for the future) is to create a set of recovery disks as soon as you restored the factory OS. This way you have a copy of your R&R partition and can restore from the disks if something ever messes up the partitions on the drive.
BigCatAndy
#4 Post by BigCatAndy » Tue Jul 20, 2021 8:44 am
Hello
This laptop was not really in use, so it is not critical. But yes, I cannot. Actually, there are no OS partitions at all, because I - occasionally - deleted them by GPartEd.
This would be OK, but R&R even does not try. After approximately 4-5 seconds it says "Product Recovery failed to restore system" - without explaining details.
Actually, the HDD is completely useless. I found a set of ISO images for T60, I download them now. I hope, this will help me.
One question: should I start with "R&R_bootable"-disk?
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
#5 Post by dr_st » Tue Jul 20, 2021 9:02 am
The first one in the set of ISO images should be a bootable R&R disk. When you run the recovery from those CDs/DVDs, the state of your hard drive should not matter - it will wipe all partitions and recreate them from scratch.
BigCatAndy
#6 Post by BigCatAndy » Tue Jul 20, 2021 3:30 pm
I could recover Windows XP using found ISOs, but this English Windows XP. Not critical, I will use Linux anyway.
But I really would like how I can "re-enable" IBM_SERVICE partition. I mean, this nothing else than all ISOs together.
Regards,
Andrey
- in use -
(3) TP T450s
- in museum -
Users browsing this forum: No registered users and 98 guests
