X230 died and won't turn back on
X230-X280, X390 Series
gypsumfantastic_
#1 Post by gypsumfantastic_ » Tue Jul 27, 2021 2:05 am
I was tinkering with it over the last few days. I tried replacing the ram but then switched back. I also installed Vantage and set battery threshold. I noticed it wasn't charging so I switched off the threshold again. Then I left it turned on and plugged in. When I returned it was turned off and would not turn back on. Prior to this, the bitlocker screen kept appearing on boot asking for a password every time which I thought was strange. The PSU makes a quiet but audible hum if I hold it to my ear. When I plug in into the Thinkpad socket it noticeably changes to a distinctive clicking sound. This is with the battery removed.
Now there are no lights or any signs of life. I tried removing battery and power cord and holding down power button for a minute. I also tried a different battery and removing and replacing the RAM. Nothing whether on battery or plugged in. The power light and charging light show no activity.
Is there any chance it could be a simple fix like the CMOS? Any other areas I can troubleshoot or should I assume the motherboard has randomly died?
It wasn't an expensive machine but I've put a lot of time into it and my faith in Thinkpad reliability is shaken.
Any advice appreciated. Thanks.
Re: X230 died and won't turn back on
#2 Post by RealBlackStuff » Tue Jul 27, 2021 2:16 am
Sound like a bad/dead charger that may have also damaged the charging circuit on the motherboard.
gypsumfantastic_
#3 Post by gypsumfantastic_ » Tue Jul 27, 2021 12:10 pm
Thanks for your reply. Would it be possible to diagnose this with a multimeter? Otherwise if I buy a new mobo the same thing might happen again.
munchausen
#4 Post by munchausen » Tue Aug 24, 2021 9:15 am
You can certainly diagnose the PSU with a meter, just look at the voltage between the barrel and the pin when plugged in (to the mains, not the laptop)... but try not to short them together or you may fry it!
There are multiple fuses on the motherboard. If the PSU is faulty it could have damaged the motherboard but you wont know without another charger. You can look for fuses on the motherboard and check them with a meter, they should of course measure 0 ohm (or beep with the continuity beeper) if they are OK. Fuses are marked e.g. F1, F2, F3 ... The X230 schematics are available here viewtopic.php?p=822767 if you want to check which fuses do what. And there are boardviews also in that zip which show where the fuses are, I've taken some screenshots of the top and bottom fuses for you which may help:
https://i.postimg.cc/MZ494bbj/x230-fuses-bottom.png
https://i.postimg.cc/JzCP7rFr/x230-fuses-top.png
FORUM warning:
picture(s) WAY too big, tags removed. Please read the Forum Rules, especially Section 5: viewtopic.php?f=16&t=14339
bgravato
#5 Post by bgravato » Tue Aug 31, 2021 5:45 pm
You actually want to measure it between the outside and the inside of the barrel, not the pin.
The pin is for something else: http://www.thinkwiki.org/wiki/Power_Con ... Signal_Pin
