I was running my X230 on an external display preparing and troubleshooting before installing the nitrocaster mod again. I desoldered it before because the FHD display was not working and I planned to redo the solder job. The machine was working fine and booted. I was able to enter Bios with an external display attached to the VGA port.
Before I was trying to use the original Lenovo Display without the mod. One IPS Display that I knew was broken unfortunately did not work but backlight was on and the still intact part was showing grey output. The other one was not broken(?), need to test with another machine. But only showed grey/white output all over the screen. Backlight was on but I did not see the bootscreen or anything else. Then I attached the external display, de-attached the original display and was able to boot normal and check bios etc. At one moment I got the glory idea to see if the old LVDS display maybe works now. Because all was laying open and without display on my table. I was using an external display, keyboard and mouse... was browsing the BIOS at the external screen... and I did not recognize the machine was still running and I plugged my LVDS cable in and now I am [censored]. Even without RAM no beep from the little baby. I can start it, fan is running, but no beeps and no display (internal or external). Even no external display!
How can I bring back my machine?
One odd thing is that without CMOS battery it was working before but now the machine does not start without CMOS battery. When the CMOS is not connected the green light at the start button is glowing for 1sec and that's it. When I use CMOS battery the machine is starting but the fan gets quite noisy after several seconds. Green LED stays on. It seems like the machine is still alive. But where to look? What to do to revive that baby? How can I check the Mobo if some fuse or something is blown?
Top
Double post from "Upgrading X220/X230 to FHD 1080p", locked.
x230 Mobo malfunction?
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 6564 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
can i swap the display + lid from an x220tablet to a x230 tablet chassis?
by rezenee » Wed Jan 21, 2026 8:03 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 5568 Views
Last post by rezenee
WTB] [CAN-ON] X230 Motherboard with i7-3612QE (35W Quad Core)
by X230X220 » Mon Jan 26, 2026 7:35 am » in Marketplace - Forum Members only - 0 Replies
- 4033 Views
Last post by X230X220
Will X220 Tablet palmrest fit X230 Tablet?
by tts_rayhan » Sat Feb 07, 2026 7:28 pm » in ThinkPad X230-X280 / X390 Series - 0 Replies
- 4085 Views
Last post by tts_rayhan
